compression check
Old May 21st, 2008, 11:21 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
compression check
i got 140psi for the highest and 130psi for the lowest cylinder. what is it suppose to be when it was new. the motor has 126k on the clock.
85 svo. work in progress
Old May 21st, 2008, 11:35 PM   #2
1983 mustang lx
83fox is on a distinguished road
i think the good rule of thumb goes the compression of all the cylinders has to be within 15-20% of the cylinder with the most psi. if im wrong, others will chime in.
Old May 22nd, 2008, 09:51 AM   #3
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Just as 83GT said, except I thought it was 10-15%
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old May 22nd, 2008, 08:41 PM   #4
1983 mustang lx
it might be 10-15% i knew 15% for sure but i didnt know if the other tolerance was higher or lower
Threads Similar to: compression check
compression thethirdmurph 5.0 Mustangs 3 April 5th, 2008 02:56 AM
compression? bigyam21 96-98 2 January 21st, 2008 01:12 PM
Compression mustangmanic 99-04 12 October 10th, 2007 10:01 PM
compression? matfernan1 99-04 5 August 30th, 2007 11:42 PM
Compression Tony_90fox 5.0 Mustangs 20 January 18th, 2007 09:26 AM
