Idle Problem
I just installed some 30# injectors with a Pro M 77 mass air calibrated for the injectors. My car is hunting for an idle between 800 and 1300 rpm. The check engine light comes on intermittently also. My fuel pressure is good and the car is very responsive when I give it gas. I have checked all my vacuum lines and electrical connections and everything is in place. I disconnected the battery for about 15 minutes also. Anyone have any ideas what may be causing this?
Anyone?
#3 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
what do you have done on your engine?
87 Coupe
![]() iTrader: 3 reviews
Could it possibly be the IAC? I know I had to get one of the adjustment plates that goes in between the iac and throttle body to adjust it. Car would run great but die at stop lights.
The engine is stock. I don't think it is the IAC since I did not have the problem before the injector/mass air install.
#6 | |
Holy Dick Castle!
you went from 19# injectors to 30# with out any mods? I think your running way rich
![]() Last edited by dr.gonzo!; May 22nd, 2008 at 12:39 PM. |
Try dropping the fuel pressure about 10 PSI, and make sure you have the vacuum hose going to the fuel regulator.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Those plates are band aids to hide a problem. Fix the problem and you won't need the band aid.
There is your problem. Take the 30lb injectors out and put the stock ones back in. Those 30lb injectors are only going to hurt you in a stock engine. I bet if you dynoed it the engine is making less power now than it was before you swapped injectors. More fuel doesn't add more horsepower unless you have the ability to burn that fuel efficiently. In your case the extra fuel you are getting is dumping right out of the exhaust.
Threads Similar to: Idle Problem
| problem with idle,, | tom2000r | 99-04 | 8 | April 22nd, 2008 04:44 PM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Idle problem | CharlieMerc | 94-95 | 7 | February 21st, 2008 11:11 AM |
| Idle Problem | jtlogruss08 | V6 Mustangs | 16 | May 22nd, 2007 04:21 PM |
| 99 3.8 with problem Idle | nweatherby | V6 Mustangs | 5 | April 3rd, 2007 03:13 PM |
