put my front shocks on tonight!!
Old May 22nd, 2008, 01:44 AM   #1
e3sean's Avatar
1988 lx
9.68@142
now i feel safe to drive my car it feels a million times better... i pulled the other ones off and as soon as i unbolted the top it sunk right down both were completely blown. i took it out and ripped it up on the street for a few minutes and came home.. pics to come.
<font size=4><b>MILITARY CREW
Old May 22nd, 2008, 03:39 AM   #2
95wip is on a distinguished road
Send a message via AIM to 95wip
its a world of differance aint it? what kind did you put on?
95' GT is being reconstructed!
Old May 22nd, 2008, 03:44 AM   #3
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC is on a distinguished road
How did you get the top nut off? I've tried 3 or 4 times and ended up darn near stripping that grove out.
BTW, I have no air tools, so if it can't be done with regular hand tools I'm screwed.
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old May 22nd, 2008, 09:21 AM   #4
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
I have the cash for brand new suspension, but I'm going with a new motor and fi first.
8( my shocks aren't terrible but my frotn end slams down hard on any pothole. Lucky you. I was ganna get the kyb shocks and struts with steeda lowering springs. Any ideas on a place to just buy struts?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 22nd, 2008, 09:38 AM   #5
e3sean's Avatar
1988 lx
9.68@142
i got lakewood 90/10's from ebay they were 105 each
Old May 22nd, 2008, 09:44 AM   #6
e3sean's Avatar
1988 lx
9.68@142
u take thewheel off first then the calaper. then using a big ass breaker bar and a cresent wrench "i had to use a 2 ft pipe at the end of the breaker bar" to break those 2 huge nuts loose. then once those are off the 3 bolts that hold the top plate on the strut tower are removed then the shock will fall as one whole peice. then using a 10mm wrench on the tip with a wrench for that top nut u can get that nut off then switch all the bushings put the nut back on and then the shock will go right back up just put the 3 bolts thredded on. u can use a jack to align the arm and the new shock to put the bolts in, tighten and your set.
"try and get the tower plate in the same place you took it off from use a sharpie to mark it or something"
Old May 22nd, 2008, 10:34 AM   #7
nolife's Avatar
91GT, 88GT, 02GT
From underneath, I moved the plastic protective boot out of the way and attached a pipe wrench to the shaft of the strut to hold it from spinning, then a socket and a breaker bar to the nut on the top. The pipe wrench on the shaft will tear up the shaft and ruin the strut it but you are replacing it anyway.
Maybe not the easiest way but it worked.
Old May 22nd, 2008, 12:02 PM   #8
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
I have my front springs from h&r and tockico on my vert and the catconverts are about 3 inches off the ground. I should have stuck with the H-pipe that came with the car(not stock)
Old May 23rd, 2008, 12:40 AM   #9
e3sean's Avatar
1988 lx
9.68@142
here are some updated pics
Old May 23rd, 2008, 02:20 AM   #10
JohnC's Avatar
1997 Mustang GT
13.56@102.94
Thanks for the tips, guys! I'll try that out!
1997 Mustang GT
My Garage
Old May 23rd, 2008, 02:31 AM   #11
ha you are better off finding a buddy with an impact wrench took me about 2.5 minutes per side to put my new struts in! seriously air tools = good investment
Old May 23rd, 2008, 02:40 AM   #12
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
Those heads look good bro! Cant wait to see everything together!
Old May 23rd, 2008, 03:15 AM   #13
1992 Lx
11.39@119.24
im pretty sure im still gona beat you
Old May 23rd, 2008, 09:04 AM   #14
e3sean's Avatar
1988 lx
9.68@142
i already did the fronts.. i have air tools i have just about every tool i need to build this car from the ground up.
Old May 23rd, 2008, 09:22 AM   #15
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
Just out of curiosity what made you decided to go with the lakewood 90/10's over the more streetable 70/30's???
I'm going lakewood up front to and I was going to g with the 70/30's so I'm j/c....
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old May 23rd, 2008, 02:50 PM   #16
e3sean's Avatar
1988 lx
9.68@142
well i was going to get the 70/30 but i pushed buy it now on the 90/10's so i just stuck with them... it drives great it seems to be very streetable. i kept them cause they are better for launching and my car will be at the track more then a typical street car.
Old May 23rd, 2008, 03:03 PM   #17
nolife's Avatar
91GT, 88GT, 02GT
You just want to some post some pics with the tires off the ground
Old May 23rd, 2008, 03:10 PM   #18
e3sean's Avatar
1988 lx
9.68@142
you bet your ass i do... that is my goal i dont care if its only 1" those tires will eventually come off the ground... i may have to buy skinnys and get a full tubular front end but it will happen..
Old May 23rd, 2008, 05:11 PM   #19
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
nice man
i just put my strange adjustable's on the front yesterday and its night and day better. i took two totally different struts off my car. they were almost completely blown. now it has a nice ride till the rear tires hit the bumps.
Old May 23rd, 2008, 05:41 PM   #20
e3sean's Avatar
1988 lx
9.68@142
i just did my rear shocks bout an hour ago and one of those were blown so i had one working shock on my car but now it drives nice.. i also had a rattle i couldnt figure out till i took the wheel off the rear sway bar on the passanger side only had one bolt in it but it was falling out.. i couldnt find another so i just tightend the shit out of the one thats in there until i get another one..
Threads Similar to: put my front shocks on tonight!!
torq spec for front and rear struts and shocks? RanGer498 99-04 3 March 22nd, 2008 04:01 PM
about to put new brakes front and back Paulnhbtx 99-04 1 January 8th, 2008 12:34 AM
Popping In Front End When I Put In Drive Or Reverse droppedbass87 General Tech 6 November 3rd, 2006 02:52 PM
85 GT Front And Rear Shocks... Replacement Needed stevemaman General Tech 1 October 12th, 2006 01:06 AM
