The power of the 5.0
I have been looking at the 360 Trick Flow top end Engine kit,I am wanting to buy it. This is what I have done so far to my 93 5.0,BBK Cold Air intake,Bassani O/R X pipe,Bassani Cat Back,70MM Throttle Body,BBK Underdrive Pullies,BBK Shorty Headers,3.73 Gears,Subrame Conncetors,AOD (Just rebuilt),AOD HP Shift Kit,and a 2400 Stall Converter. So should I buy the Trick Flow engine kit? Im also going to upgrade to the Aeromotive Fuel Kit,and get my Rear end Built.
1993 GT
13.2@105
I am pretty sure you will be happy if you do it......
#4 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
I think most people go with a 24# injector and im not sure on the maf. 76 guessing? and a walbro fuel pump wouldnt hurt
![]() Last edited by dr.gonzo!; May 22nd, 2008 at 07:16 PM. |
I would probobly get 30# injectors just to be sure, that will be a potent motor. PRO-M makes 10-15 more horsepower than c@L almost every time, i have dyno proof.
1987 ford mustang gt
well see when shes done
the max on the 19's are around 300 at 100 % duty cycle i believe.
the 24's will bee great for what you are doing/. |
#8 | |
#9 | |
#11 | |
Holy Dick Castle!
found this in a diffrent site (stangnet.com)
How much hp can 24 lb injectors support? - Mustang Forums at StangNet Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines. Example: 19/.5 = 38, 38 x 8 = 304 HP 24/.5 = 48, 48 x 8 = 384 HP 30/.5 = 60, 60 x 8 = 480 HP 36/.5 = 72, 72 x 8 = 576 HP 42/.5 = 84, 84 x 8 = 672 HP The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85. 304 HP x .85 = 258 HP 385 HP x .85 = 326 HP 480 HP x .85 = 408 HP 576 HP x .85 = 490 HP 672 HP x .85 = 571 HP Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI. 24# will work but if you want room to improve go with the 30#
#12 | |
How much horspower will I be making to the Wheels and the Crank?
1988 lx
9.68@142
the best ting u can do is get the c&l & a stock sensor if u are going to get a dyno tune /chip the chip gets along with the stock ford sensor. pro m is a nice meter too but a lil more money.
Threads Similar to: The power of the 5.0
| Too much Power??? | turismo374 | V6 Mustangs | 52 | April 18th, 2008 11:28 PM |
| PI = No Power? | AnglicoGT98 | 96-98 | 24 | May 18th, 2007 05:15 PM |
| Power? | SlvrStang | V6 Mustangs | 14 | April 14th, 2007 10:19 PM |
| v6 power | niners2046 | V6 Mustangs | 20 | January 30th, 2007 06:31 AM |
| More Power | guywithanepi | V6 Mustangs | 10 | September 21st, 2006 10:32 PM |
