351 Heads
will a set of 351 heads with bigger valves fit and work on a 302 block bored 30 over and "f" cam with holley intake and holley carb
#2 | |
Re: 351 Heads
11.47@120.58
No you don't use a 351w intake. The 351w heads are the same as 289 / 302 heads. Running an F cam and with larger valves, you should definately check for piston to valve clearance. Not sure if you'd have problems or not, though it'd be close either way.
#4 | |
thanks.....i know not to use 351c heads as the 351c is a big block..thanks for the help fellas
#6 | |
#7 | |
Re: 351 Heads
Yes they will fit but you will need a bushing to reduce the head bolt size from 1/2" to 7/16". What year are the heads? If they are not 69 351W heads you are wasting your time because a 5 liter (E7) head will out flow it. Your best bet would be to get a set of GT40P heads of a 97 1/2" or newer Explorer.
#8 | |
A 351C is a small block and yes the heads will work on a 302 block but you will need pistons specific to the Cleveland head (Boss 302 pistons) and an intake designed to fit those heads (Boss 302).
im not sure of the year of the heads..its for a friend of mine...but much good info..ill pass it along thanks......hes not looking for much more than stock replacement..he cant afford much and he came across the 351 heads...thanks
#10 | |
for example: C6=1966 D3=1973 and so forth
Previous and Current Rides: 1967 Ford Mustang Coupe 2002 Ford Mustang GT--SOLD! 1967 Ford Fairlane 500 XL--SOLD! 2003 Ford Mustang Cobra 1 of 308--SOLD!! 2003 Kawasaki Mean Streak--SOLD!! 2006 Harley Davidson Screamin' Eagle V-Rod |
more important is the casting date which will be something like this 8B16 and usually has circles on both sides that look like screws. just an example from my D4AE 351w block.
8 = year B = month 16 = day 02/16/1978 |
Threads Similar to: 351 Heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 10:01 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| 289 Heads | ezra27 | General Tech | 0 | December 31st, 2006 12:09 AM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 04:18 PM |
