1995 Mustang GT
N/A
The carb setup
Hey how’s everyone’s Stang doing? I haven’t talked on the site in a while. I’ve been in the process of moving. I have a question to whoever has carbureted there 5.0 and please don’t start jumping on me about it yet, let me explain lol. I’m living in WV and there is no place to get a good tune at all (AT ALL). Besides me working my regular job, I work at advance auto parts and I have talked to way too many performance guys and one or two girls. They all have said take the car back down to where I’m from in Virginia Beach and get it done there.
So for my conclusion, the EFI it is going to cost me a lot more cash than it would be to do a carb set up. It’s not an everyday driver; it’s my toy to play around with. A carb setup will give me a lot more options in swapping parts in and out later down the road. The only thing stock is the bottom end. I recently purchased the Weiand X-Celerator intake and the MSD distributor w/steel gear and the MSD 6AL from advanced auto. (My 20% employee discount helps, and to me that’s another reason why it’s cheaper going carbureted) The machine shop ported my heads to my intake. I am thinking about going with the holly 600 street carb with an inline electric pump with regular. Let me know what you think about all this. And for my last question, after I pull my fuel pump out of the tank how would you go about fabricating your pickup lines for the fuel. |
carb is the way to go for what you want to do with it...the holley should be fine..i dont know how far you want to go or what your plans are but as far as setting up the fuel you might want to get a cell..like i said i dont know what you want to do in the future but it is for sure the easiest way..
"That old Ford sure fast on the draw out run the Chevys and out run the law" |
1986 lx notch
9.98 @ 135
get a 650 mechanical secondary holley carb. NO IT'S NOT TOO BIG it'll run perfect and it won't be any worse on gas then a vacuum carb providing you can keep your foot out of it . I've converted more then 1 5.0 to a carb and the 650 DP has never let me down from stock motors to ones that would trap 113 mph
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
87 'Stang
13.1@105
I'm going to leave my electric fuel pump (255 walboro) in the tank when I convert. Just buy a GOOD regulator and run a bigger fuel line for a return to the tank. Carbs are about fuel volume and not pressure. Just the opposite w/EFI. There's a guy in my club running a professionally built 331 w/his electric EFI pump, but runs a good regulator and bigger return line.
87 Hatch. Holley Systemax Kit. F cam. No AC, PS and front swaybar. Built rearend. 310hp/308tq. |
You either have to take the intank pump out of the fuel pump hanger and replace with a piece of rubber hose (what i usually do) or buy the conversion hanger from granetelli for like $100 which is basically what I done with the rubber hose cept they use a metal line. Then mount you a holley blue fuel pump with a regulator and fuel system is done there. I have never heard of anyone using the efi pump with the carb.
I like holley but not a fan of DP on these engines. I have a 600, but think you might be better suited with a 670 street avenger.
1986 Mustang GT t-top time piece! |
#6 | |
1990 LX hatch
You only have to make up a bigger returnline if your pressure creeps up. |
#7 | |
1990 LX hatch
Any return style FPR(carb pressure) will work with a intank EFI pump, and a carb. |
1995 Mustang GT
N/A
Everyone I have talked to said that I haft to take out my in tank pump and either buy the $100 or so kit or fabricate the lines. Which is the right/better way to go? To me, taking out the efi pump is the best way to do it. Will a 670 be too big? I definitely don’t want to go too big. I want to do it right. My duration of my cam is 226, the carb I was looking at said it was able to perform up to a 230 duration. What is your thoughts???
I personally have never seen the efi pump used on a carbed car.
I am using a 4160 holley 600 on my car. That or the street avenger 670 should be plenty for you. Look on holleys site they have a thing on there that help you choose what carb will be best for you.
#10 | |
Going to a carb is going to cost you money. The carb, intake, regulator, fuel lines, distributor,throttle cable, etc is all going to cost money. Not to mention the loss of low end power. But if you are stuck on doing it then you will need to purchase a few things. You don't need to do anything with your fuel pump or tank. Aeromotive makes a regulator that will allow you to use the EFI fuel pump for a carbureted application. Using the Aeromotive regulator will save you alot of hassle.
1989 Mustang LX
10.98@126.7 NA
As long as you use a by pass regulator you can leave the intank fuel pump. I personally remove the intank and modify the pickup and run a Holley Black with their regulator.
Never fast enough.
1983 mustang lx
a barry grant 575 or 650 speed demon would also be a good carb. if your setup isnt all that modified go with the 575, too much of a carburator can be a bad thing.
89 Mustang Lx
Carb - $120.00
Intake - $130.00 Fuel lines - $10.00 Throttle Cable - Use the one you have. Will work with bracket that connected to the intake Throttle cable bracket - $10.00 Return Spring - $5.00 A Few hundred bucks and a little research, you will have your parts without spending thousands and not even close to $400 bucks, depending on your particular setup. To tell the truth, it's good they have EFI pump to carb setup for the pump but to be honest, just take your pickup tube out, remove the pump and install a fuel line that will be to the bottom of the tank or better yet, scratch all of that... Get a fuel sump. It's like $20.00 on ebay and go to your weld shop or if you have one, weld it in the dead center of the tank which the sumps are made for your application and just by your lines and your aN fittings. Should cost you no more than $40.00 total. Then get your Fuel pump so we're talking a mere $160.00 average. Pressure will creep up on you and you will have constant carb flooding and will piss you off daily. Maybe piss you off by the minute.
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot Last edited by teal89; May 27th, 2008 at 02:43 PM. |
No it wont. WTF you getting your information from?
1986 mustang gt convert
i say mechanical with a stick,vacum carb with a automatic,unless you can tune a carb pretty good..
#17 | |
89 Mustang Lx
Also, I am getting my information from experience. I had a particular setup using the efi pump and an Aeromotive regulator. Sooner or later you will get to much gas into the carb and end up flooding it. My experience so I have every right to say what I said. If it's wrong then simple mistake. So explain how that can be resolved. What regulator can be used with an efi pump for carb'd vehicles?
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot |
1987 ford mustang gt
well see when shes done
Damn you say their is something wrong with everything you get or have seen, First its trick flow now aeromotive.
#19 | |
#20 | |
If you found a carb for the price thats good. THen good find! Way to shop around is what I say.
Threads Similar to: The carb setup
| Classic body taillight setup vs. s197 setup | rockybalboa | Visual | 1 | May 22nd, 2008 12:08 PM |
| carb fuel setup | chaosstangman | 5.0 Mustangs | 0 | January 16th, 2008 05:14 PM |
| Carb ?'s | gtstang87 | 5.0 Mustangs | 3 | November 18th, 2007 06:25 PM |
| carb setup question | 86gt5liter | 5.0 Mustangs | 2 | May 15th, 2007 05:16 PM |
| carb ? | terribleonexx88 | 5.0 Mustangs | 11 | December 4th, 2006 01:21 AM |
