88 Lx
brake conversion
i have a 88lx 4lug axis. I want to convert my rear to disc brake. i know the RX-7 fits on it but do any of you guys have done something else???? And i also want to put my front disc bigger... do any of you guys have ideas on what to do??
haha gts have bigger discs in the front we are lucky
88 Lx
its not to hard to put are's bigger... just need to do are brackets
88 Lx
does anyone have a brake conversion setting or ideas please?
87 Coupe
![]() iTrader: 3 reviews
87-88 turbocoupe rear end for the rear disc brakes and I believe the 94-95 gt rears also work. 87-88 turbo coupe are 3/4 " longer each end though cuz of the abs on it but it does work.
88 Lx
yeah but you become 5 lug.... i want to stay 4lug. That's why i dont want to take the 94 rear brakes. I know the thunderbird turbo coupe brakes work but i wanted to know what you guys that have modded stang put as brakes. I want to do my brakes in the idea of having a 400hp stang. what do you guys have???
#7 | |
1987 ford mustang gt
well see when shes done
and how do you plan to make 400 hp? |
88 Lx
its not for now...but im think of upgrading injectors,cam,change the flywheel, and then probobly a kenne bell supercharge.
88 Lx
are you modded??
88 Lx
are you modded?
03 GT, 92 coupe 2.3T
its a little on the pricey side at 699.99 but they have a discount for us mustang forum members.
87-92 REAR DISK BRAKE CONVERSION KIT, 4 LUG, WITH STANDARD ROTORS MUSTANG |
87 Coupe
I used the thunderbird brakes on mine.
why do you want disc in the back for looks??
88 Lx
non its just because its better....but ive talk with a couple of people and change my mine. Ill put everything 5lug, ill be larger. is it complicated to swap for 5 lug? and expensive??
1983 mustang lx
79-93 5 Lug Ford Fox Body Mustang Conversions hopefully that helps. it shouldnt be that expensive going through a junkyard for your parts
87 Coupe
you can all the parts for a 5 lug swap from the junkyard for as much as you would a 4lug disc setup if not for cheaper.
Threads Similar to: brake conversion
| Disc Brake Conversion | wonders_of_a_V8 | Classic Mustangs | 6 | January 20th, 2009 10:16 AM |
| SN95 disc brake conversion,.. | Hunt_chevs | 5.0 Mustangs | 4 | April 26th, 2008 12:03 PM |
| Disc Brake Conversion | gotboost562 | 5.0 Mustangs | 8 | November 10th, 2007 06:38 PM |
| 13 inch cobra brake conversion help | cybertech | 5.0 Mustangs | 6 | October 17th, 2007 01:28 PM |
| 6 brake light conversion | 99mustang232 | Visual | 0 | November 27th, 2005 03:46 AM |
