stock 5.0l (89 gt) compression ratio
Old May 24th, 2008, 10:02 PM   #1
EscortSportage's Avatar
1989 Mustang GT 5.0
what is the compression ratio for a stock 89 gt 5.0
if ima boost it i need to lower the comp ratio so im thinking of getting a very thick head gasket to just take .5 off or something...
Old May 24th, 2008, 10:35 PM   #2
1983 mustang lx
83fox is on a distinguished road
or you can get dished pistons too
Old May 24th, 2008, 10:38 PM   #3
1987 ford mustang gt
well see when shes done
you will be fine with the factory pistons and c/r it is 9.1
Old May 24th, 2008, 10:52 PM   #4
1983 mustang lx
what are you planning for boost? if youre running 6-10 psi you should be safe. any more than that and you will need to do some modification.
Old May 24th, 2008, 10:58 PM   #5
really you could even go up to 12lbs but i would not go with more than that. I WOULD also suggest a set of good head gaskets
Old May 24th, 2008, 11:07 PM   #6
1983 mustang lx
12 psi depending on the mileage of the motor and shape of the stock head gaskets. +1 on the good head gaskets, its embarassing to be in a car thats trying to show off and all of the sudden the motor pisses itself.
Old May 25th, 2008, 05:25 PM   #7
1989 Mustang GT 5.0
MLS head gasket
multi layered steel...
Threads Similar to: stock 5.0l (89 gt) compression ratio
compression ratio CharlieMerc 94-95 3 May 17th, 2008 10:38 AM
Compression Ratio invisa stang 5.0 Mustangs 8 January 8th, 2008 06:28 PM
compression ratio mustangrebuilder Classic Mustangs 13 August 14th, 2007 10:08 PM
stock compression ratio and combustion chamber volume??? 83five0 5.0 Mustangs 1 May 15th, 2007 06:12 PM
96 gt compression ratio 96_gt_stanger 96-98 3 March 2nd, 2007 11:52 PM
