1990 5.0 LX Notch
Headers
I have 351w heads on my 302 block. The headers that came with the car come real close to my starter and it is getting heat soaked. Can I run these even though it is not a 351w block??
BBK Performance 15690 - BBK Mustang 351W Swap Headers - summitracing.com |
#2 | |
You have 351 heads on your 302...? If thats what you are saying... yeah it should be fine... may try heat wrappin the header though
'92 Fox Body, Audio King '96 BMW 525d |
does that even work?
1990 5.0 LX Notch
does what work???
1987 ford mustang gt
well see when shes done
you cannot run 351 headers on your 302 b/c they are made to accomodate the larger deck height of the 351
351W heads do fit on a 302 but you have to use head bolt bushings or you can run into alignment and clamping issues between the heads and block. A 351W uses a larger diameter head bolt than a 302. Everything else about the head is the same as a 302 head. Running a 351W head is not an upgrade over a 302 head. Most years the heads had the same port volumes, chamber volumes and valve sizes.
1990 5.0 LX Notch
Still have not answered the question that was asked.
#8 | |
Iownastang answered your question.
1989 GT asked if that even works which sounds like he is asking if 351W heads can be used on a 302. I answered the question.
1979 mustang 5.0
hopefully 11's when complete
OK time out here...........
small block ford heads are small block ford heads. You can take the heads off a 351w and put them on a 302,289,260 ect...... Only 351 Cleavland and modified ford heads are different The deck height on a 351w is slightly higher than that of a 302 to accommodate for the longer stroke which gets you the extra 49ci.... Now I have those BBK headers on my 351w, they most likely will NOT work with a 302 because they will be touching either the steering, starter motor, bell housing or maybe the floor.... I think your problem with the headers cooking the starter motor has absolutely NOTHING to do with your heads, it has to do with the either the headers being a shitty design or the maybe the starter motor you put in is bigger or shaped a little different, in turn putting it closer to the headers. P.S. you could try putting heat reflective tape on the starter motor you know.... maybe wrap the headers is asbestos as well.....
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
1990 LX hatch
I have 351w long tubes on my 302, and they are too close to my clutch cable. They cost me a 30$ a month clutch cable bill.
i asked if it worked? like if it does anything
1990 5.0 LX Notch
Well I starting having the problem with the stock starter. So I installed the PM mini. Still getting the same problem. I did notice the other day when I went to start it after the motor was hot it would drag and almost seemed like the battery was dead. Then a puff of smoke from the passanger side. Had my son jump in and try and turn it over while I looked in the starter area. He tuened the key and SPARKS a flyin. WTF!!!
Threads Similar to: Headers
| Long tube headers or short tube headers? | 2much4u | 99-04 | 20 | October 11th, 2009 09:49 PM |
| (2005-2008)Long headers vs shorty Headers | RetroKid | V6 Mustangs | 9 | April 12th, 2008 12:14 PM |
| JBA Headers vs BBK headers | 06GTMustang89 | 2005 - 2010 | 70 | March 18th, 2008 06:59 AM |
| Which Headers To Use | bob | 5.0 Mustangs | 35 | January 9th, 2008 09:25 AM |
| Headers | jaamfoster | 96-98 | 5 | April 14th, 2007 10:51 AM |
