braking problem
Old May 25th, 2008, 10:39 PM   #1
MIGHTYJO3YOUNG's Avatar
1992 mustang Lx
13.4@ 106
MIGHTYJO3YOUNG is on a distinguished road
braking problem
i finally got my car running today after a month of workin on it anyways it revs real nice everything seems to be good except for my brakes. I took it for a test drive and it braked fine the first time i put the foot on the pedal, but once i let up and went to brake again it was as hard as a rock couldnt brake at all. Wait a minute and i could brake again but only once then hard again. Anyone know what might be the problem? thanks fellas. Ill put some pics up of the motor tommorow when its light out again.
Old May 25th, 2008, 10:46 PM   #2
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
vaccum line to the brake booster popped off maybe
85 svo. work in progress
Old May 25th, 2008, 11:11 PM   #3
1992 mustang Lx
13.4@ 106
possibly. could it be anything else?
Old May 25th, 2008, 11:17 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
My Mustangs sit unused for long periods. Typically I clean off the pads and rotors with emery cloth or a wire brush and brake cleaner and even with that, it takes a few days before the brakes are back to normal. The time it takes driving around depends on if the rotors just have surface rust or if they are worse and have some pitting. I think with only a month, you should have only surface rust. You could have moisture in your lines or a leaking wheel cylinder or caliper piston.
Old May 25th, 2008, 11:21 PM   #5
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
I'd have to say vaccum line as well. If its still in the booster, you might not have any vaccum at all.
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old May 25th, 2008, 11:27 PM   #6
1992 mustang Lx
13.4@ 106
What do you mean by if its still in the booster? ill check to see about vaccuum lines tommorow. Does the vacuum line go into the driver side fender?
thanks for the help guys. This site is like school for my car i can learn pretty much anything from u guys!
Old May 26th, 2008, 02:00 AM   #7
1988 Mustang GT
N/A
In this picture the part is still in the booster. The vacuum line just isnt hooked to it.
Old May 29th, 2008, 12:51 PM   #8
1992 mustang Lx
13.4@ 106
U guys were right! it was lack of vacuum! the line from the intake manifold was kinked going to the vacuum manifold= used all the vacuum and took about 15 seconds to charge again till i could brake. All better now though and better than before Im happy!
Old January 21st, 2011, 02:03 PM   #9
1991 Mustang LX 5.0
sincityz is on a distinguished road
Send a message via MSN to sincityz
Hey guys im having the same problem. I checked the vacuum lines like you said and they are all fine. Does this mean the booster is bad?
Tired 200xxx mile 91 LX 5.0, BBK CAI, 70mm Throttle Body, Under Drive Pullies, BBK Shorties, MSD Wires and Coil, Electric Fan, Custom X-Pipe, Pypes Violators Dumped
Old January 21st, 2011, 02:06 PM   #10
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
if you hear a hiss(air escaping) when you press the brake its most likely the booster.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Threads Similar to: braking problem
Braking-Steering Problem. Dansby V6 Mustangs 2 April 11th, 2008 07:01 PM
Braking bad whitemustang02 The Clubhouse 8 March 9th, 2008 11:39 PM
hard braking Stang187 V6 Mustangs 17 February 3rd, 2008 11:47 PM
engine braking nutterbutter 99-04 7 January 30th, 2008 07:43 PM
Stang Stalls while braking and idleing Tscott 99-04 10 January 16th, 2007 10:01 PM
