gt40p spark plug question
Old May 25th, 2008, 11:19 PM   #1
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
they say long tube headers wont work with the p's, is this because there's no room to change the spark plug once the headers are installed? i hope that's why, seeing as how you can buy specialty spark plug sockets for working in the crowded f body(camaro) engine compartments, and they would be easy enough to make at home.
i would like a set of gt40p's, but if they wont work with long tubes for some other reason, i'll go with gt40's.
anything else i should grab besides upper/lower intake and heads?
also, with a mild cam, how much difference will the 40's/p's make?
i have no clue of the exact cam.
Old May 26th, 2008, 01:27 AM   #2
e3sean's Avatar
1988 lx
9.68@142
i dont see why long tubes wouldnt work... the only reason that some headers wont work is cause the spark plug is angled and with most wires unless its a 90* elbow then some of the wires will touch the header.. to eliminate that problem u need to look for a header that will go out a few inches before it starts to turn down like some go stright from the head and immiadetly start turning down and some will go stright out about 2 inches before starting to turn. i am sure there are long tubes out there that will work just ask around.
<font size=4><b>MILITARY CREW
Old May 26th, 2008, 02:24 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There are several long tube headers that will work with P heads.
Old May 26th, 2008, 11:56 AM   #4
11.8@113...150 shot
yes, but i already have a set of long tubes and im not sure what kind they are.
Old May 26th, 2008, 01:25 PM   #5
e3sean's Avatar
1988 lx
9.68@142
to they go out stright before they turn down or do the just statt turning down right away?
Old May 26th, 2008, 02:04 PM   #6
jrh_1980's Avatar
89 Mustang LX
7.90@90mph 8th
jrh_1980 is on a distinguished road
If worse comes to worse, accel makes header plugs that have a shorter body. you may have to do some searching to get some but well worth it. had some trouble with the long tube headers i have and the angle of the plug coming out of my 65 289 heads. I used those plugs and they worked great. you would have to use a different part number than i did because the gt40 have 5/8 plugs.
Old May 26th, 2008, 02:10 PM   #7
1994 Mustang GT
DrHoward is on a distinguished road
you should find out what kind of long tubes they are because there are a few sets that work with p heads
And those shorter spark plug sockets work well with them
1994 Mustang GT HCI N2O yada yada yada
http://www.cardomain.com/id/bigshirtlesspete
Old May 26th, 2008, 03:15 PM   #8
11.8@113...150 shot
heres some pictures of my long tubes
Old May 27th, 2008, 10:30 AM   #9
11.8@113...150 shot
nobody can tell if these headers will work with gt40p's?
Threads Similar to: gt40p spark plug question
Pulse Plug vs. Spark Plug BlckBullitt01 99-04 4 May 18th, 2008 02:51 AM
Spark plug Stanglover1250 V6 Mustangs 23 May 11th, 2008 05:40 PM
spark plug ?'s tgk 94-95 1 August 25th, 2007 07:29 AM
Spark Plug question zerofx150 99-04 0 August 9th, 2007 09:04 PM
spark plug help mm49271 V6 Mustangs 3 February 5th, 2007 07:14 PM
