#21 |
Long tube headers will always make more power across the entire RPM range. I've seen it on dynos and at the track on my own vehicles. They make useable power that you want for street driving. Long tube headers scavage the cylinders better than shorties. Aftermarket shorties aren't worth the price because you usually don't gain anything. If you are going to buy long tube headers don't look for the best price or you will run into steering shaft issues and starter issues. I don't understand the hot floorboard issue that Ryan mentioned since the exhaust pipes run in the same location as the long tube headers if you were running shorty headers. I guess I've never experienced a hot floorboard and I've driven some of my cars for up to 21 hours non stop at a time. I guess it goes back to buying good headers versus cheap headers. I have never seen an engine bay get hotter either. In reality the engine bay should be cooler because long tube headers move exhaust gasses faster than shorty headers. Its the same theory as dual versus single exhaust. A dual exhaust system runs cooler because it moves the gasses quicker than a single exhaust system but the draw back is the dual exhaust system rusts out quicker because it doesn't get as hot. If heat is that big of an issue get ceramic coated headers.
#22 |
¡ʇsnq ɹo uʍop ǝpısdn
i agree with darrell on the floor board thing, i have not had a problem with mine, but i have ceramic coated, they rub on the floor pan... and they were kinda cheap... about the same price as shorties
#23 |
The exhaust is cooler, which means the heat went somewhere (i.e. the engine bay/ floor board).
Long tube headers have about 3 times the surface area as shorties, which means they have about 3 -times the heat exchanging area. Ceramic does help a lot.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#24 |
1989 GT
KB 2.1L Flowzilla
I'm not good at explaining this stuff, so read these first:
The truth about exhaust backpressure and torque Exhaust Backpressure http://www.veryuseful.com/mustang/te...Scavenging.pdf More can be found with google |
#25 | |
#26 |
The reason for it to run cooler is because it is spread out more through a bigger area, like single to dual exhaust. Its not that more heat is escaping thru the pipe walls, the heat is flowing faster thru a larger area and not moving slow like in a single exhaust pipe. Its like moving your hand thru fire. If you move it slow it gets hot. If you move it fast you don't feel a thing. Like myself and others have said, I've never had any heat issues with any of my Mustangs and they've eventually all had long tube headers. I drove my 91 GT non stop to Las vegas which was a 21 hour, 1800 mile one way trip. No hot floor boards.
#27 | |
The 3 1/2 collectors could be an issue since I was referring to 2 1/2 and 3 inch that I've used on most of my street beaters. I did have 3 1/2 inch collectors and exhaust on my black car and never had any issues with hot floor boards on that car but my collectors and exhaust were not tight to the floor. I guess I would try some different headers if I were you because you seriously shouldn't be getting hot floor boards like that. Exhaust pules do not matter with 02 sensors. They read the gas, not the pulse. If the pulse matter then it would matter if you had the sensor on an individual port or down in the exhaust pipe which it doesn't matter. I've seen them mounted in various locations on various cars. Where you run into problems is on OBD2 and up cars with no cats.
#28 |
Directly from TMOSS
"A word of caution to those who install long tube headers. In order for the O2 sensors to operate properly, they must be at, and stay at, a minimum temperature. If you place the HEGO O2 sensors farther away from the head than the stock location, you may have the sensor too far away to keep it hot enough to read correctly due to the cooled exhaust gases. This causes the EEC to enrich mixture and may cause plug fowling. Ceramic heat coating the headers will help maintain exhaust gas temperature. The EEC has a timing table used to time the sampling of the O2 sensors to coincide with the arrival of the latest cylinder exhaust pulse from each bank. Moving the HEGO sensor further away (or closer for that matter) may result in an ill-timed sample, which could also cause improper air/fuel mixtures to occur due to the O2 sensor not sampling when the pulse passes the sensor. One way to compensate for the additional time needed due to adding length in the Long tube headers is to change the timing table with an EEC-Tunerâ or TwEECerâ ."
#29 | |
98 Cobra
#30 | |
#31 | |
I agree long tubes work well on carb cars and work great for a lot of people on EFI, but I just wanted to share some of the down side of longtubes, since there are some disadvantages (don't forget about starter heat soak). I saw a LS1 camaro loose 45 hp by doing a long tube swap on the dyno...that was funny (timing retard due to knock sensor).
#32 | |
98 Cobra
or just get some simulators? |
#33 | |
As far as heat soak goes, that goes back to quality versus cheap.
#34 | |
No, it doesn't work that way. The computer will keep pulling timing until the knock is gone no matter where your initial timing is set.
Threads Similar to: 3inch exhaust cause damage?
| engine damage? | garydahl | 2005 - 2010 | 23 | May 5th, 2008 09:43 AM |
| Will this damage my 6? | Youngin | V6 Mustangs | 49 | February 20th, 2008 11:36 AM |
| Did i do damage | mikevm78 | 99-04 | 31 | February 12th, 2008 06:30 PM |
| 3inch exhaust too much? | 91cobra5.0 | 5.0 Mustangs | 40 | January 31st, 2008 02:32 PM |
| Damage done to the mustang. | Hourofpain | Visual | 13 | October 23rd, 2007 06:55 AM |
