just some math ive gathered
Old May 27th, 2008, 12:09 AM   #1
1983 mustang lx
83fox is on a distinguished road
no questions, just some information i thought would be helpful to others since horsepower and torque numbers are frequently asked.
FINDING HORSEPOWER FROM THE 1320
Horsepower=weight x 0.4 x 1/4 mile MPH
282
CALCULATING HORSEPOWER AND TORQUE
Horsepower=RPM x Torque
5,252 RPM
Torque=5,252 RPM x Horsepower
RPM
FINDING THE RIGHT CARBURATOR FOR YOUR APPLICATION
Most street driven motors have a volumetric effeciency (aka VE) of 75% to 80% and more performance goals have a VE of 80-95%. VE can be tested on a dyno.
this is to help choose the most efficient carb for your set up
VE x cubic inches x Max RPMs
--------------------------------- = cfm
3456
CUBIC CENTIMETERS TO CUBIC INCHES
cc/16.4=ci
COMPRESSED HEAD GASKET VOLUME
B=Bore
B x B x Gasket Thickness x 0.7854=Compressed Head Gasket Volume
PISTON/DECK HEIGHT VOLUME
Bring a piston to TDC and use a dial indicator to measure the distance from the top of the piston to the deck of the block, its usually between .008 to .025, unless the deck was shaved down.
The measurement you got is going to be represented by the letter D in the following formula:
B x B x D x 0.7854=Piston/Deck Height Volume
PISTON DOME/DISH VOLUME AND COMPRESSION RATIO
First things first, measure the volume of your pistons, even flat top pistons with valve reliefs. You can do this by either using a graduated cylinder or by contacting the company that makes the pistons. Then covert the cc's of volume of the piston into ci's with the formula above.
Here comes the fun part, the compression ratio
V=Cylinder Volume
C=Combustion Chamber Volume
G=Compressed Head Gasket Volume
P=Piston Dome Volume
D=Piston/Deck Height Volume
V+D+G+C+P
D+G+C+P
just plug in your actual numbers and divide the sum of the top number by the sum of the bottom number and that will give you your true compression ratio
Old May 27th, 2008, 12:10 AM   #2
ujslost's Avatar
Good Info right there.
I say this should be a sticky.
Old May 27th, 2008, 09:04 PM   #3
tmoss's Avatar
tmoss is on a distinguished road
if you go the download section of my website you can pick up an Excel file called "helpful calculations" that has a BUNCH of stuff in it..................
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old May 27th, 2008, 10:26 PM   #4
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
don't forget HP estimates based on boost.
(Boost pressure/14.7 + 1) x (N/A Horsepower) = Boosted Power
example: (8 PSI / 14.7 + 1) x (245 BHP) = 378.333
this is based on air pressure at sea level and does not take into account parasitic loss.
i have no mustang. so don't listen to anything i say.
Old May 27th, 2008, 10:42 PM   #5
1983 mustang lx
^oh yeah i forgot completely about that
anyone else have some math they want to add to this thread?
Old May 27th, 2008, 10:43 PM   #6
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
I've never been good at it, so you can count me out
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Threads Similar to: just some math ive gathered
Santa Math Reset The Clubhouse 4 December 24th, 2007 03:47 PM
im an idiot at math Onemanzu The Clubhouse 29 October 30th, 2007 07:22 PM
Unbelievable Math Problem Racerchik02 The Clubhouse 68 July 20th, 2007 01:18 PM
Ricer math? 2000Mustang All Other Vehicles 25 April 25th, 2007 02:38 AM
