T-5 transmission fluid
LinkBack (8) Thread Tools
Old May 27th, 2008, 02:20 AM   8 links from elsewhere to this Post. Click to view. #1
fastford3388's Avatar
1991 Mustang GT
fastford3388 is on a distinguished road
Send a message via AIM to fastford3388
Hey guys! i'm putting a T-5 in my mustang and i'm wondering what fluid to use? I want to use some good stuff, preferably synthetic. My friend says GM synchromesh is really good in his dodge stealth. I was wondering if you guys had any experience with synthetic fluid and what is best? Mobil 1? B&M synthetic?
thanks
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
Old May 27th, 2008, 02:20 AM   #2
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
royal purple
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old May 27th, 2008, 02:22 AM   #3
bullitt5576's Avatar
2001 Bullitt
bullitt5576 will become famous soon enough
royal purple is by far my favorite oil/lubricants
MM NEW EDGE COBRA CREW #2
Old May 27th, 2008, 02:46 AM   #4
1991 Mustang GT
how many quarts do i need?
Old May 27th, 2008, 02:58 AM   #5
1991 Mustang GT
also, i've heard bad things about synthetics. something about it not having enough friction in order to mesh with the syncros making it harder on the synchros to shift. should i go synthetic? also, should i go dexron mercon or syncromesh? royal purple makes syncromax which is synthetic syncromesh.
Old May 27th, 2008, 09:35 AM   #6
e3sean's Avatar
1988 lx
9.68@142
get dexron III(3) or IV (4) with mercon you dont need a synthetic,and it will be exactly 3 quarts.
<font size=4><b>MILITARY CREW
Old May 27th, 2008, 11:45 AM   #7
ryans88gt's Avatar
I've always had good luck with plain old D/M III. I've heard some guys use lightweight 30W synthethetic gear oil for track only use, but I have never tried it.
Old May 27th, 2008, 11:45 AM   #8
1991 Mustang GT
i know ford recommends dexron/mercon but i wanted to put some better stuff. Has anyone used syncromesh from GM? my buddy uses it in his AWD Stealth and he says stealth guys swear by this stuff. I'm just curious because i want to put the best stuff in my transmission. something a little better than regular dexron/mercon
Old May 27th, 2008, 11:56 AM   #9
ryans88gt's Avatar
No, use D/M III.
Using other stuff will not be better, it will be a quick route to a rebuild.
Old May 27th, 2008, 12:19 PM   #10
Hasselm8's Avatar
'99 Mustang Gt
IDK
Hasselm8 is on a distinguished road
Originally Posted by 96GTRagTop View Post
royal purple
+1
"A wise man can learn more from a foolish question than a fool can learn from a wise answer. "
Old May 27th, 2008, 02:17 PM   #11
nolife's Avatar
91GT, 88GT, 02GT
What would make Syncromesh "better" in a T5 and what is wrong with dexron/mercon? They are two different fluids with different characteristics. Maybe one is better then the other but I personally would not switch without some actual evidence or at least a theory of why one was better than the other in the T5. I did see that Amsoil suggests their version of Syncromesh can be used in a T5 although they make no claims of it being better in a T5 or that it is a replacement for Mercon/Dexron, only that it would be easier for the retailers to stock only Sycromesh instead of a bunch of different types of transmissions fliuds.
AMSOIL Manual Synchromesh Transmission fluid is a versatile transmission lubricant. It reduces inventory needs, is readily available and is cost effective compared to vehicle manufacturer branded products.
Recommended for automotive and light truck applications that require synchromesh transmission fluid. Applications include manual transmissions and transaxles such as New Venture NV T350, NV 1500, NV 2550, NV 3500, NV 3550, NV 5600, and Tremec T4, T5, T18, T56, T176, TKO500, TKO600, TR 3450 and TR 3550. Replaces MTF-94 fluid for Land Rover, MG, and Mini Cooper. Replaces Honda Genuine MTF fluid for manual transaxles and Texaco MTX fluid.
Old May 27th, 2008, 09:31 PM   #12
e3sean's Avatar
1988 lx
9.68@142
i would use AMSOIL but thats cause my buddy is a dealer and i get it cheap but for something like that i would use what ford says to use.
Old May 27th, 2008, 10:14 PM   #13
nolife's Avatar
91GT, 88GT, 02GT
I use Castrol brand Dexron myself, the Amsoil site was the first one I found that mentioned any comparison or reference to a T5.
Old May 27th, 2008, 10:51 PM   #14
1987 ford mustang gt
well see when shes done
I was thinking of buying vavoline dexron mercon atf for mine
Old May 27th, 2008, 11:54 PM   #15
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
i put mobil 1 synthetic in mine and if i flog it in 1st i rele have to slam second or ill miss it would the synthetic fluid make it harder to shift.
85 svo. work in progress
Old May 30th, 2008, 04:34 PM   #16
1991 Mustang GT
thats a good question. anyone know? I ended up getting schaffers (sp?) synthetic dex/mer III oil. they guy at the speed shop said its completely un-advertized and they've been around since mid 1800's. He said the fastest guys around put that stuff in their trans and its the only stuff that holds up.
anyone used it? should i stay away from synthetic?
Old May 30th, 2008, 04:36 PM   #17
ryans88gt's Avatar
I've heard of people putting a light weight synthetic gear oil in their T5s for drag race use only. If drag race use only sounds like what you use your car for, then go ahead and try it. If not, stick with Dex III, if it aint broke don't fix it.
Old May 30th, 2008, 04:51 PM   #18
1991 Mustang GT
yeah this stuff is dexron mecron III its not lightweight gear oil but would the synthetic oil make a huge difference if it's a street/strip car? is it gonna be ok? I don't want drivability issues but i want good performance from my fluid. its just regular dexron mercon synthetic stuff
Old May 30th, 2008, 04:55 PM   #19
e3sean's Avatar
1988 lx
9.68@142
it could. remember syncros work on friction. they need to be able to make 2 gears turning at differnt speeds to the same speed in a fraction of a second if it cant get that grip it will grind into gear. thats why old non world class t-5's use gear lube cause they were all brass but now they are fiber and carbon backed so they have to be able to grab smoothly.
Old May 31st, 2008, 08:24 AM   #20
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
Redline MTL
Originally Posted by FX4DTUF View Post
a camaro pulls up next to me and i think to my self what would jesus do at a time like this then it hits me he would launch it and power shift the shit out of it
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/72945-t-5-transmission-fluid.html
Info.co.uk - t5 transmission fluid - www.Info.co.uk This thread Refback July 10th, 2011 12:43 PM
Info.com - t5 transmission fluid - www.Info.com This thread Refback May 24th, 2011 08:14 AM
Info.com - t5 transmission fluid - www.Info.com This thread Refback May 16th, 2011 05:12 AM
Info.com - t5 transmission fluid - www.Info.com This thread Refback April 22nd, 2011 08:41 AM
Info.com - t5 transmission fluid - www.Info.com This thread Refback April 1st, 2011 11:27 PM
Info.com - t5 transmission fluid - www.Info.com This thread Refback December 9th, 2010 07:50 PM
Info.com - t5 transmission fluid - www.Info.com This thread Refback December 5th, 2010 04:26 PM
T-5 transmission fluid This thread Refback May 27th, 2008 03:20 AM
Threads Similar to: T-5 transmission fluid
What Transmission Fluid? Murderjetz General Tech 8 November 10th, 2007 11:39 PM
TRANSMISSION FLUID ROUSHME661 V6 Mustangs 17 July 14th, 2007 02:04 PM
transmission fluid firefly1241 5.0 Mustangs 10 April 1st, 2007 04:33 PM
3650 transmission fluid B0B 99-04 4 March 15th, 2007 05:25 PM
transmission fluid 1990CA50 5.0 Mustangs 1 December 12th, 2006 01:48 PM
