89 Mustang LX
7.90@90mph 8th
![]() iTrader: 1 reviews
Fuel Pressure readings??
I need to know the proper procedure for checking fuel pressure. I hooked up a gauge to the schrader valve and started the vehicle. i got about 37lbs of pressure then when i hit the throttle it would jump to about 40 for a split second then drop off to 30lbs or so. shouldn't it stay consistent?
Remove and plug the vacuum line attached to the FPR. It will stay consistent with that line removed. Stock setting is 39#. Plug the vac line back in when your done
89 Mustang Lx
that will be it.
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot |
Threads Similar to: Fuel Pressure readings??
| Fuel Pressure Regulator Leaking Fuel | Buttaz | V6 Mustangs | 4 | August 17th, 2007 11:41 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| No fuel pressure, Fuel gauge went above full and stayed. | woodz72 | 96-98 | 6 | July 10th, 2007 06:58 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
| Fuel Pressure | hmotes | 5.0 Mustangs | 11 | December 2nd, 2006 12:27 AM |
