Starter location
Old May 27th, 2008, 04:18 PM   #1
tehdwarvenn's Avatar
tehdwarvenn is on a distinguished road
Send a message via AIM to tehdwarvenn
Starter location
my starter popped out of position so it cant start the car right now, so i need to move it back and put it in tight cause i think it got loosened when my car was worked on.
couple questions:
Where is it?
How easy is it to get to?
What bolts (sizes) does it use?
Would i have to take the transmission down or something crazy like that?
P.S. im 17 years old with a jack and 2 jack stands. that is my "lift" =)
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Old May 27th, 2008, 04:55 PM   #2
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
1. remove the negative battery cable from the battery terminal.
2. put it up on the jack stands.
3. disconnect the large cable from the terminal on the starter motor. (the starter is on the left/back/bottom. (left as you look at the engine from the front of the car))
4. remove the starter motor mounting bolts.
5. turn the wheels if you need to for additional access to the starter. or take the left front tire completely off.
installation is reverse of removal.
not sure of the bolt size. if you've got a socket set, you should be able to find the right one.
mine recently stopped working and it had sheered the mounting tabs right off of it. so make sure it's not broken like that before you try to tighten or reinstall it.
i have no mustang. so don't listen to anything i say.
Old May 27th, 2008, 05:06 PM   #3
ok thanks much. gonna go do it right now =)
p.s. passenger side would have helped more than me turning to my car outside and thinking.. ok .. left hand... side... "ok got it"..
Old May 27th, 2008, 05:11 PM   #4
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
yeah. i thought about that after i posted.
Old May 27th, 2008, 05:48 PM   #5
sniperrider's Avatar
sniperrider is on a distinguished road
Send a message via MSN to sniperrider
its a bitch lol i found it easier with a ass load of extensions running through the(left side) headers.....lol
90 lx hatch
Old May 27th, 2008, 07:09 PM   #6
alright went to lowes and they donated a bolt to my cause, got it in and everything's perfect.
i have a stock k-member. and that was a BITCH, but i got it with some minor muscle pains. MINOR!
thanks for the instructions.
For all those people who need instructions and come across this thread:
-Loosen passenger side tire lugs in the front
-Jack car up so wheel is off the ground (the higher the better)
-Take off wheel
-The starter is right next to the bellhousing right under where your headers connect to your exhaust pipes (if you have shorties)
-both bolts are visible but the top one is hard to get to. must use an extension on your ratchet for the top one.
-the bolts are (size) 3/8-24 UNC and are about 1.8''-2'' long. dont remember the size of the hex.
Hope this helps.
Old May 27th, 2008, 09:03 PM   #7
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
glad you got it worked out dude.
Threads Similar to: Starter location
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
Location??? CBSTANG 99-04 1 February 15th, 2008 06:03 AM
VA Location?? 1994vert Northeast 5 September 9th, 2007 04:02 PM
location??? sb2f5marine69 5.0 Mustangs 1 April 14th, 2007 06:03 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
