Discussing can i add a supercharger safely in the 5.0 Mustangs Forum. Originally Posted by 83fox with nitrous you should be in the 11's. if you ...
Old May 29th, 2008, 01:00 AM   #41
1987 ford mustang gt
well see when shes done
Originally Posted by 83fox View Post
with nitrous you should be in the 11's. if you have the right suspension set up and a rearend that can hold all the power without blowing its own brains out, you may see very low 11s or maybe high 10s with a good tail wind haha
It depends on how much he sprays but I would guess 11.5's on the jug and slicks.
I prefer nos and nx kits they are both nice setups.
Old May 29th, 2008, 01:06 AM   #42
1983 mustang lx
im more of an all throttle, no bottle kind of guy. but when you build your motor to what you want and its still not enough, n2o is a good way to fix that.
id think that a decent suspension set up would bring his et down to the low 11s
Old May 29th, 2008, 01:07 AM   #43
you watch pass time dont you.
Old May 29th, 2008, 01:08 AM   #44
HELLRAZR94's Avatar
1994 MUSTANG GT
i have a fidanza stage 2 clutch,373 gears and a almost full max motor sports suspension
Old May 29th, 2008, 02:02 AM   #45
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
quote from a kid at sheets "everybody knows after you rebuild your motor you always gotta do it again" he threw a supercharger on a similar setup to yours...
Old May 29th, 2008, 12:50 PM   #46
HELLRAZR94's Avatar
1994 MUSTANG GT
y do it again? just add to it
Old May 29th, 2008, 01:36 PM   #47
Smirnoff's Avatar
1982 GT t-top
the kid was a complete idiot, he thought after you rebuild a motor it'll always blow up the first time so you gotta do it again...but to make things worse he threw a s/c on a high compression motor
Old May 29th, 2008, 07:25 PM   #48
HELLRAZR94's Avatar
1994 MUSTANG GT
i cant say anything i wanted to also, but these guy got me away from that and im going with nos
Old May 30th, 2008, 11:36 PM   #49
Smirnoff's Avatar
1982 GT t-top
good... but you asked so that makes you not an idiot he simply thinks he knows all
Old May 31st, 2008, 01:00 PM   #50
1983 mustang lx
haha i watch it like its my job. they just made the way i feel a lot more cooler
Old June 2nd, 2008, 12:57 AM   #51
HELLRAZR94's Avatar
1994 MUSTANG GT
so u guys think i could maybe do mid 11s
Old June 2nd, 2008, 01:53 AM   #52
on a 100-150 shot yes.
Old June 2nd, 2008, 02:39 AM   #53
blue90lx's Avatar
90 lx hatch
13.02@103.62
yeah with that kind of compression your doin the right thing with getting the n20 and man it likes the compression. And with your setup you should be in the 11s real easy with a little spray and a good tire "MICKEY THOMPSON" or what ever tire you like man. but good luck with it.
to many parts and money to be so slow
F/S 1986 mustang vert asking $6500
http://www.moddedmustangs.com/forums...ml#post1277818
Old June 3rd, 2008, 05:30 AM   #54
HELLRAZR94's Avatar
1994 MUSTANG GT
yeah i want to go with a150 shot
Old June 3rd, 2008, 11:11 AM   #55
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
the guy who built the motor said 12.1
I doubt it. For one you would not be filling your car up at gas pumps in California with 12:1 compression. Another thing is I'm sure the stroker kit came with flat top pistons. I haven't seen very many off the shelf 347 kits come with domed pistons. A typical 347 with a flat top piston and a 60cc chamber (same as the RPM heads) will put you at about 10.5:1. Still a bit high for a supercharger and probably a bit high for California gas but will run ok with some timing pulled out of it. Unless you had dish pistons with the stroker kit, you won't be running a supercharger on this engine.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old June 3rd, 2008, 01:57 PM   #56
HELLRAZR94's Avatar
1994 MUSTANG GT
the pistons r domed and the compression is 11.1 and there is a shit loud of mustang over here that r running 12.1 compression on pump gas
Old June 3rd, 2008, 02:52 PM   #57
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
If they are domed you are looking at a minimum of 12.75:1. There are not alot of people running 12:1 on pump gas over there. What you have is alot of people that don't know what their compression ratio is that just spout off numbers. 12:1 on pump gas is not mechanically possible without retarding the timing several degrees which is going to defeat the purpose of the high compression anyway and will make less power than a 10:1 engine with full timing. 12:1 with an aluminum head needs about 104 octane minimum.
Old June 3rd, 2008, 03:05 PM   #58
let me see the part number to the stroker kit you bought. You said it was 12.1 and now it 11.1 whats the deal?
Old June 3rd, 2008, 03:19 PM   #59
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
I don't think he is throwing numbers around intentionally. It sounds like someone is pumping him full of shit so he doesn't know any better.
Old June 3rd, 2008, 03:24 PM   #60
HELLRAZR94's Avatar
1994 MUSTANG GT
the guy who did the motor was going to be between 12.1 11.1 i dont have the part number because of the fact that i didnt build the motor, but i dont need to bullshit this is a computer bro why lie
Threads Similar to: can i add a supercharger safely
best to add hp mystang0673 99-04 23 September 16th, 2007 01:08 AM
add mpboy 99-04 9 September 12th, 2007 04:06 PM
what does it all add up to? sleezy 96-98 9 August 24th, 2007 01:41 AM
What to add... GDStang V6 Mustangs 10 April 7th, 2007 10:17 PM
How do i get rid of small scatches on my car safely? SonicStang Visual 21 March 29th, 2007 02:21 AM
