Setting Timing before first startup
Old May 28th, 2008, 11:20 PM   #1
91 gt 5.0 is on a distinguished road
So I've pulled my engine, done everything I needed to do and have dropped it back in. I'm getting to the point where I'll hopefully be starting it tomorrow. My question is......how do i position the distributor so that it is within a workable range for the startup? Like where should the rotor be when the the pointer on the balancer says ATC for instance? I realize I'll need my light to set it for real, but this is my first time so I don't want to really mess it up.
Old May 29th, 2008, 12:44 AM   #2
1986 mustang gt convert
86gtconvert is on a distinguished road
put piston at tdc you can do it by carefully using a screw driver in #1 spark plug hole and turn motor over in short burst.till its at the top,and screw driver is pushed out furthest..rotor needs to be pointedto #1 spark plug wire..if it back fires chances are its 180 degrees out..set the timing with a gun at about 5* adv and work from there asuming you have a H.O motor..
Old May 29th, 2008, 06:29 PM   #3
ryans88gt's Avatar
At top dead center (i.e. both intake valve and exhaust valve are closed on #1 piston use a dial indicator to verify the TDC timing mark on dampener is actually TDC.
Now you drop the distributor and the rotor should point exactly at 12 O'clock.
Then just turn the base slightly clockwise and start it up and immediately set the base timing. If it will not start, try moving the distributor base clockwise or counterclockwise. Once it starts immediately set the timing.
Old May 29th, 2008, 06:53 PM   #4
ujslost's Avatar
Note , #1 at TDC on compression stroke. Like ryan was saying.
I put my thumb over the #1 spark plug hole and have someone turn the engine over until the compression pushes my thumb of the hole slightly, then I bring it on up to TDC using the screw driver method.
Threads Similar to: Setting Timing before first startup
odd startup mscribellito V6 Mustangs 6 April 1st, 2008 11:51 AM
setting the timing dr.gonzo! 5.0 Mustangs 10 March 31st, 2008 05:34 PM
Smoke on startup? weems 4V / SVT 12 February 21st, 2008 09:18 AM
Setting Distributor and Timing on a 93 5.0 that is carbed. 83 5.0 5.0 Mustangs 11 September 11th, 2006 06:57 PM
Setting the timing? MySallyMI 99-04 10 August 11th, 2006 12:10 PM
