LinkBack (1) | Thread Tools |
#1
1990 mustang gt
eventually
compression/blown
what is the stock compression on a 5.0? what do yall recommend to do to a stock block and internals to get it ready to be blown?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
2008 Hammock Rodeo Champ
9.0:1 (i think)
how much boost?
i have no mustang. so don't listen to anything i say. |
89 Mustang Lx
Now fortunantly the 5.0 H.O's were already ready to go for boost and Nitrous. BUT the head gaskets can only take so much. You can but 8psi is the maximum I would do. Replace the head gaskets and you can do 10psi. Just make sure you do timing before you start slamming on it otherwise, you'll get the "bag of marbles" in your cab
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot |
1990 mustang gt
eventually
these are the heads im going to put in there
Trick Flow Specialties TFS-51400004 - Trick Flow Twisted Wedge Street Cylinder Heads for Small Block Ford - summitracing.com here is the cam Trick Flow Specialties TFS-51402000 - Trick Flow Track Max Hydraulic Roller Camshafts for Ford 5.0L - summitracing.com im looking at all internals now but i dont know what stock size is to do a replacement.. i know im going to need to repunch the bores b/c it does have 140000 miles on her
89 Mustang Lx
YOu don't have to but if I were you, make the power because you'll have more compression. Bore it .30 over nd since you're talking internals now, get the Trickflow 11.1 or 13.1 compression pistons, no need to go blown. Or you can get the 9.5.1 pistons
#6 | |
9:1 is the stock compression. Don't do anything to the stock block or internals. Bolt the blower on and go.
Going from 9:1 to 13:1 compression is not going to make more power than a blower even at low boost levels.
1990 mustang gt
eventually
but i was thinkin about a complete engine rebuild b4 i went
Then rebuild the engine. Its up to you, its your car. Just realize, Darrell is right. You can just bolt the supercharger on, and run.
Keeping in mind ofcourse, you'd need a booster pump of some sort, or bigger fuel pump all together. An FMU, or larger injectors. An adjustable fuel pressure regulator, and a good o2 meter. Otherwise, leave the engine alone, and boost it.
89 Mustang Lx
Well I highly understand that. I ned to put my periods in the right spot LOL. I was talking 11.1 or 13.1 being on all motor and the 9.5 was meant for the blown project. I was just throwing stuff out.
#11 | |
89 Mustang Lx
He can bolt in on and go but you are right to for performance and safety concerns but if all he wants is a blown stang then he's good with 8psi on stock internals. Now if he wants to blow the shit out of it figurablly speaking on more of 10-15psi, then yeah, a booster fuel pump, bigger injectors, o2 meter, and MAF sensors is a hell of an idea.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/73274-compression-blown.html
| compression/blown | This thread | Refback | May 29th, 2008 01:44 AM | |
Threads Similar to: compression/blown
| What you think of this blown 86 | 86ttops | 5.0 Mustangs | 5 | February 21st, 2008 10:02 AM |
| 2V Block blown...what to go with? | fbodypilot | 99-04 | 24 | February 14th, 2008 03:34 PM |
| Blown | whitefox89 | 5.0 Mustangs | 17 | November 25th, 2007 08:42 PM |
| Going Blown.... | G.T. Rags | Modular Mustangs | 26 | October 14th, 2007 08:12 PM |
| I'm Getting Blown! :o) | MaverickMLFD371 | 2005 - 2010 | 11 | December 4th, 2006 09:38 PM |
