1989 mustang LX
11.42 @120
vortech T-trim VS S-trim
Just wondering what power difference they make. If there both running 15 pounds of boost does the T-trim make more power if so about how much more.
89 hatch.....4,000 dollars..vortech supercharger kit.....3,800 dollars...built 306 windsor motor.....3,000 dollars beating a 75,000 dollar z06 corvette....PRICELESS UNTIL I SOLD THE CAR |
94 GT
i think one is quiet and the other isnt
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
RLY SRS
The T-Trim can run alot more boost...It is less efficient at low boost but shines at higher boost...
The S-Trim cant run as much boost...It is more efficient at low boost but not higher boost.... I run a T-Trim on mine... The T-Trim is loud as hell too... |
At 15 PSI the only difference will be the outlet temperature (i.e. how hot the blower heats the air up to get to 15 PSI). However, there is no way to determine the efficiency of a given blower at 15 PSI, without considering the restriction (i.e. engine). On smaller motors the S-trim could be more efficient at 15 PSI and on larger/freer flowing motors the T-trim could be more efficient. You'll have to look at compressor maps and the type of motor it is going on to figure out which will work better for your application. If that is too much, call vortech and ask them.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Just curious. Are we comparing the V1 T-trim, to the V1 S-trim? Or the V1T, to the V2S?
Ryan > Well said bro.
1989 mustang LX
11.42 @120
v1-t to the v1 -trim
RLY SRS
At 30#'s the S-Trim has no chance of the efficiency of the T-Trim at the same boost level...
1989 LX Vert - 1993 Notch
Fast
It's not "Boost Levels" ............ it's CFM flow.
Boost is NOT a measure of air flow. It's a measure of "back pressure" to airflow. Picking the right S/C comes down to how many CFM's a given engine size will need at a given boost level and rpm. Basically the S-trim will not supply enough CFM for bigger cubic inch engines running a good amount of boost or smaller engines running insane amounts of boost. The CFM flow for a given engine at a give boost level is pretty easy to figure out. We can go into how to run the math and read compressor maps if you want but thats almost a whole thread in and of itself.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
RLY SRS
I know that boost is just a level of back pressure...I am just saying...The S-Trim shits out at around 600rwhp...
2008 Acura TL Type-S - 2008 EB Ford Expedition - 2002 Boosted GT - Sold Google+
RLY SRS
S-Trim
1989 mustang LX
11.42 @120
thanks for the info guys
that 11 second quarter mile in your sig BLOWN, is that just with the 306 and no power adders?
#13 | |
Ahhh, but 600 hp on a 2 liter engine could be a lot more than 30 PSI.
RLY SRS
But we are not talking about a 2 liter engine here though...
Since when is "boost" a level, or measure of backpressure?
Always? You are measuring the build up of pressure in the intake that the car cannot consume.
But in reality it isn't that simple, because the higher the pressure in the intake, the more air that is forced into the motor. Obviously a motor will produce more power at 15 PSI than at 10 PSI, so part of that extra 5 PSI is being consumed. You probably need some advanced algorithms and calculus to really understand how boost effects power output from different compressors and engines.
The OP didn't specify, he could have a 4-banger.
*Shakes head*
![]() I think your mis-understanding my question bro.
RLY SRS
In his sig
built 306 windsor motor |
1989 mustang LX
11.42 @120
the 11 sec pass I with the supercharger at 7lbs of boost.
Threads Similar to: vortech T-trim VS S-trim
| vortech jt trim... | mystang0673 | 99-04 | 2 | March 25th, 2008 09:15 PM |
| vortech s trim | flattusmaximus78 | V6 Mustangs | 9 | October 12th, 2007 10:40 AM |
| v1 s trim vortech | stoes | General Tech | 7 | March 29th, 2007 12:04 AM |
| I need Help with a Vortech S-trim | 02ponypackage | V6 Mustangs | 67 | January 10th, 2007 06:41 AM |
