best power options for stock shortblock
Old May 29th, 2008, 12:19 PM   #1
scout68's Avatar
scout68 is on a distinguished road
I have a 90 5.0. It has a GT40 Tubular intake, 75mm throttle body, 24lb inj, wet nos, 3.73s, C4 (will likely go with 3000ish stall, will be used 95% 1/8th mile...minimal street. I'm new to 5.0s and NOS and I want the car to be fun and as economical as I can make it. I know racing is not economical, but I want to as thrifty as I can. I figure that I will make a few mistakes with the NOS so I'm counting on running through a few shortblocks. I would like to come up with a nice cam/head combo that would work well with the stuff I already have and a stock shortblock without notching pistons so I can use salvage yard engines. I was considering the patriot heads but I'm not sure that they will hit the pistons or not. This is just gonna be a toy that will be played with at the track, not a serious run every weekend car. If my wife, in-laws, kids, etc wanna run it...lets go have some fun. Any suggestions would be greatly appreciated.
Old May 29th, 2008, 12:27 PM   #2
1994 Mustang GT
DrHoward is on a distinguished road
stop calling it NOS, N2O people will get mad at you, lol
You can run up to around 150 shot of nitrous without major problems as long as you set it up correctly
I bought my nos dry system used for 200 dollars then spent around 100 dollars on the odds and ends that I required, so you can do it cheap as long as you look around
As far as I know the patriot heads work fine on stock pistons, but I am not an expert on them
1994 Mustang GT HCI N2O yada yada yada
http://www.cardomain.com/id/bigshirtlesspete
Old May 29th, 2008, 06:57 PM   #3
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
zex dry kit 125 shot , autolite 23 or 24 plugs, 190 lb or 255 intank pump ( not necessary but considering the stock one is almost 20 years old it's cheap insurance ) 93 octane and no more then 12 degrees initial timing and yer good to go
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old May 29th, 2008, 09:06 PM   #4
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
I believe hes inquiring about a "Heads and Intake" combo, not about Nitrous. Trick Flow Specialties is what you need to look into, if your not interested in modifying your pistons. They've got matching intake and head configurations for all types of applications. Give them a whirl.
Old May 30th, 2008, 01:08 AM   #5
1986 mustang gt convert
86gtconvert is on a distinguished road
trick flow-edelbrock is good,rhs heads,afr is good..there are tons of good proven combos outhere no reason to do a bad set up unless you cant read...hastings offers a book that has proven combos and the hp graphs they had a dynos
Old May 30th, 2008, 10:19 AM   #6
scout68's Avatar
Thanks Goblin, you're exactly right. I'm looking for the best heads/cam route to go with stock pistons. I already have an N2O system on the car along with a GT40 tubular intake. I may just stick with iron heads and spray the snot out of it. Which explorer heads are the best and what years/vehicles did they come on. Thanks guys for the help....
Old May 31st, 2008, 07:59 PM   #7
Goblin's Avatar
88mm
Old June 1st, 2008, 01:43 AM   #8
demonicus's Avatar
1988 mustang LX coupe
demonicus is on a distinguished road
get those iron heads reworked and you'll be fine. We have ppl running 200shots on stock motors with no issues.
the breaking point of the blocks is 550tq and 500hp to give you an idea. of course you can break it at 300hp if enough detonation is present. have fun.
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars
88coupe- lookin for a new powerplant
Old June 1st, 2008, 01:34 PM   #9
86_Notch's Avatar
1986 lx notch
9.98 @ 135
buddy of mine was running high with a stock short block, ported stock heads, rpm intake, big roller cam , and a 750 carb, you don't need any special heads for nitrous use, if you're on a budget get some gt 40s, on my 86 capri , i had a stock short block ( from an 88 mustang ) e cam, gt 40s , cobra intake, 24 lb injectors with a matching meter, 65 mm tb, and with a t5 and 373s i was running high 11s with a 75 shot
Threads Similar to: best power options for stock shortblock
power options... again... trueballerisme V6 Mustangs 29 October 4th, 2007 05:46 PM
Dyno Tuned Power options |TH|BLaCkStAnG 99-04 4 April 16th, 2007 07:54 PM
stock rim tire options? 94v6blkndred V6 Mustangs 0 March 20th, 2007 11:51 AM
Best Power Options PONYBOY14 General Tech 8 January 30th, 2007 07:18 PM
