1983 Mustang GT
N/A
Vibration above 3k
I have vibration above 3k in every gear (Tremec 3550). I have 3:73's, but they were there when I got the car. Could this be my gears?
48.47@ 12.58
I would think more along the lines of a bad u joint
1983 Mustang GT
N/A
How hard is it to change the u-joint?
48.47@ 12.58
How about 3k rpm when not moving or moving at a decent speed while in neutral. Any difference there? U-joints, driveshaft and rear gears problems should not be related to a certain engine rpm, they move proportional to the cars speed, not the engines speed.
1989 Mustang LX
10.98@126.7 NA
+1. If the vibration leaves and comes back everytime you shift gears and throttle up, it's somewhere between the harmonic balancer and the input shaft of the trans. U joints could cause a similar vibration that would seem to get worse when the shaft is put under heavy load and then calm down when going at a constant speed but it would still be there when ever the shaft is rotating.
Never fast enough.
1990 mustang gt
eventually
i just had that prob and it was the harmonic balancer and it just kept getting worse.. but when i changed out the harmonic balancer it was all good
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
1983 Mustang GT
N/A
The vibration is at & above 3k, whether I'm in 1st doing 30, or 4th doing 45. I can rev it up when it's out of gear, and the vibration is there above 3k. So now I'm guessing it's not the u-joint?
2008 Hammock Rodeo Champ
what about motor mounts.
i have no mustang. so don't listen to anything i say. |
1990 mustang gt
eventually
+1 balancer
like i said i had this exact same prob
Threads Similar to: Vibration above 3k
| 96 gt vibration | jagstang96 | 96-98 | 3 | February 23rd, 2008 04:02 PM |
| vibration | haywood11 | 5.0 Mustangs | 2 | October 28th, 2007 08:41 AM |
| Vibration | shurb125 | 5.0 Mustangs | 13 | May 8th, 2007 09:23 AM |
| vibration | hmotes | 5.0 Mustangs | 8 | January 5th, 2007 02:30 PM |
| vibration | cali 5.0 | 5.0 Mustangs | 7 | June 8th, 2006 07:44 PM |
