Compression check?
how do i do it?
General directions...
Get a compression tester (auto parts store for about $40 or they may lend you one for free). Warm up the engine. Shut off the engine and remove the ignition coil wire and take all the spark plugs out. Screw in the compression tester to one hole at a time. Crank the engine with the starter for about 10 revolutions. Read the pressure gauge, remove the compression tester. Repeat 7 more times for the other cylinders. Depending on how your readings look, you may have to go back and do further tests on some cylinders.
oh thanks bro valueable ifno alright sounds good bro thanks
all motor
92 coupe
9.94@136.40
he forgot u should chock open the throttle blade 100%.
alright thanks guys
1986 mustang gt convert
aslong as they are all around 5 lbs or so of each other you should be ok..depending on milage...if one reads 135 and the next one to it reads 120 chances are you have a leaky or blown gasket between those..
i have 57 k miles on it
Threads Similar to: Compression check?
| compression check | terribleonexx88 | 5.0 Mustangs | 3 | May 22nd, 2008 08:41 PM |
| Compression | Blackblurr_00GT | 99-04 | 7 | January 1st, 2008 01:14 PM |
| compression? | matfernan1 | 99-04 | 5 | August 30th, 2007 11:42 PM |
| compression | greenstallion | 99-04 | 4 | March 8th, 2007 06:40 PM |
| Compression | Tony_90fox | 5.0 Mustangs | 20 | January 18th, 2007 09:26 AM |
