LinkBack (1) | Thread Tools |
#1
car problems
hey guys, i have a 1988 lx 5.0. iam having some big problems with it now. it is my d.d. for a few months then it will be my project car. but i bought it from my friend about a month ago and have had nothing but problems with the thing. my first was that it sat at his house for a year so i replaced the starter,soleniod,all the battery cables. but while it was sitting the computer had gotten wet and the car wouldnt idle and when you were coming to a stop it would just stall out completely and it seemed like just a computer problem cause my buddy said the computer had gotten wet. so i bought a new computer and it still runs like that, it wont idle at all so im wondering what the hell is wrong with this thing i can barely drive it. now my second problem: i installed my tach yesterdy, and now the car wont run lol, i spliced all the wires through the fuse block and the green wire to the negative side of the coil. now when i go to start the car and it just shuts off right when it starts running. i did splice the green wire from the tach into the negative side of the coil wire so i thought tht was the prolbem so i cut the splice out and butt connected the negative coil wire together again and it still wont run. someone please help me with this damn car lol
91 lx vert
the idling problem could be your IAB you can take it off and clean it and see as far as the tach im not sure ive never ran into that problem im sure somebody on here has maybe they will help you out
If you aint breaking parts your not going fast enough |
iab??? it seems like its an electrical problem and it runs better when i pull the maf sensor plug.. but it stills stalls out and if by chance it doesnt stall at a light then hen it does idle its jumpy going from 500-1500rpm lol
1988 lx 5.0 rebuilt motor,t-5 tranny,rear end. worked heads with an f-cam bbk longtubes, full msd ignition, cold air intake, 3.73's, and suspension work, and fuel pump, soon to be drag car. |
1989 LX Vert - 1993 Notch
Fast
You need to inspect the MAF sensor.
Look inside. They make MAF cleaner spray. It should run worse with MAF unplugged. The IAC motor is on the side of the throttle body and controls idle at zero throttle. They get old dirty and stuck. You need to check the TPS voltage. Do google search. Tons of threads on how to do it. I'd check the balancer. Bad balancer can cause all kinds of weird problems |
48.47@ 12.58
holy hell I do believe you just received your first forum rep from me.
so the maf or balancer could cause a big problem like that?? idk its weird it ran perfect than sat for a year and now it runs like shit lol i dont get it
Fast
Could be a kazillion things, these are just good places to start.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
damn that sux lol, i was gonna think about a whole new wiring harness cause my buddy said the weatherstripping is bad so the computer got wet (thats why i bought a new one) so im thinking maybe the harness is shot?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/73382-car-problems.html
| car problems | This thread | Refback | May 30th, 2008 08:13 PM | |
Threads Similar to: car problems
| Car Problems | DarkSidejoker | V6 Mustangs | 7 | January 10th, 2008 12:34 PM |
| More Problems With My Car... | graystang01 | V6 Mustangs | 12 | November 14th, 2007 10:58 AM |
| Car problems! | stanggurl2 | 5.0 Mustangs | 6 | June 13th, 2007 11:25 AM |
| Car Problems | bigbadtalontsi | 5.0 Mustangs | 4 | January 15th, 2007 08:52 PM |
| Help Please (Car Problems) | 98mustang98 | V6 Mustangs | 1 | October 25th, 2006 10:49 PM |
