soon to be drag car help
Old May 29th, 2008, 07:51 PM   #1
gyellow is on a distinguished road
well in a few months my car will become a strictly strip/street car, my goals for the car is high 9's to mid 10s on spray. now my questions are how do i get there?? i dont know anything about 5.0s, im a camaro guy. as of now my car has a rebuilt stock motor,rebuilt trans with upgraded clutch, rebuilt rear with 3.73's. the motor has a cam,bbks, full msd, cold air intake,then normal stuff. my buddy ran it and ran a 14.1 spinning till third so im thinking its a low 13 sec. car if it had traction. i want to run at least a 200 shot of spray so i know i will need a built motor, any suggestions?? (stock block, boss block wht heads,cam) now as for the tranny i know my stock t-5 prolly culdnt handle the power right? so i would more than likely go to built auto, suggestions??(c4,c6 where to get them, how ti install them in a 5.0) also the rear end, would i be best off putting a 9" in there? i need help on all aspects of the car cause as i stated before i know nothing about mustangs. the car does have full suspension on it now..but i need some advice on wht motor,tranny,and rear end would bet suit my needs for my goals i have in mind. Thanks gregg
1988 lx 5.0 rebuilt motor,t-5 tranny,rear end.
worked heads with an f-cam bbk longtubes, full msd ignition, cold air intake, 3.73's, and suspension work, and fuel pump, soon to be drag car.
Old May 29th, 2008, 07:54 PM   #2
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
351 windsor stroked to a 408, or maybe even a big block. built c4 transmission, and built 8.8 rear
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old May 29th, 2008, 08:02 PM   #3
as for the rear a built 8.8 will last? so what should i do first to the rear end? upgraded axles,the posi and what else?? or do they sell complete boltins?
Old May 29th, 2008, 08:05 PM   #4
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
it would probably be cheaper to build one yourself. the 8.8 rear can hold over 900hp if built right. you might even want to look into a spool for it if it will be seeing a whole lot of track time
MM 1 am boner crew
Old May 29th, 2008, 08:28 PM   #5
ok kool, thats when less thing that has to be takn out and a new one put in lol
Old May 29th, 2008, 09:21 PM   #6
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
look at my car, 10.70s @ 126 on DRAG RADIALS, i paid 1500 for the motor ( 351 flat tappet cam, dished pistons, 300 dollar windsor jr heads ) vr jr intake, 750 carb, c 4 3500 stall convertor, stock 8.8 with new clutches in the rear and 373 gears ( stock axles ) some suspension work and a 150 shot of nitrous , ( cheapie summit fuel system utilizing what is basically a holley blue pump )
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old May 29th, 2008, 09:55 PM   #7
well where did you get your tranny casue b4 i even put anymore performance parts in i want to mess with the tranny and get a c4 in there should i have one upgraded or do you think a stock one would be fine for my application?? also how hard is it to get it to fit?
Old May 29th, 2008, 10:07 PM   #8
86_Notch's Avatar
1986 lx notch
9.98 @ 135
Performance Automatic
Old May 29th, 2008, 10:29 PM   #9
k thanks man, as for the motor. do you think if i went with a boss 302 block punched it out to a 347 with an eagle forged rotating assembly, some gt-40 or afr heads and a nitrous cam with a 200-300shot i could get into the low 10's??
Old May 29th, 2008, 10:54 PM   #10
86_Notch's Avatar
1986 lx notch
9.98 @ 135
you don't need a boss block to go 10s, my buddy was running high 10s with a c4, 3000 stall, 373s, slicks, stock bottom end ( well a few versions ) ported stock heads, performer rpm intake , big cam, 750 carb and a 200 shot , altho he went thru his fair share of head gaskets and a couple of split blocks, which is why i always recommend a windsor swap, it's always cheaper and more reliable
Threads Similar to: soon to be drag car help
A Drag Car! JONJON 5.0 Mustangs 42 November 18th, 2007 07:33 PM
Exotic car drag race trev0006 Multimedia 4 November 6th, 2007 01:03 AM
Will eibach drag springs lower my car? black04GT General Tech 16 October 3rd, 2007 12:30 PM
5.0 drag car BsGms3 5.0 Mustangs 39 March 3rd, 2007 09:56 AM
