Crank pulley
Old May 29th, 2008, 08:35 PM   #1
1987 ford mustang gt
well see when shes done
Crank pulley
My crank pulley is not lined up with the rest of the pullies it is recessed 7/8 of an inch farther back than the water pump pulley What can cause this"?
Old May 29th, 2008, 08:37 PM   #2
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
thrust bearings?
Old May 29th, 2008, 08:40 PM   #3
Are you saying I should use thrust bearings behind the pulley on the bolts.
The car has been apart so long i do not remember if it was like this when i got it.
Old May 29th, 2008, 08:45 PM   #4
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
no they're inside the engine. they keep the crank from walking back and forth. if the crank hasnt moved front and back, then its prlly just an alignment issue
edit- u wrote 7/8 of an ich? thats just about a whole inch, then i wouldthink its an alignmetn issue
Old May 29th, 2008, 08:47 PM   #5
Oh sorry I had my head in the gutter, duh.
No im pretty sure the crank hasnt moved, well im gonna go see if i can figure this crap out.
Im pretty sure it is just an alignment issue/
Old May 29th, 2008, 09:11 PM   #6
Man i cannot find anything that look to be out of the ordinary. Im stumped
Old May 29th, 2008, 09:13 PM   #7
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
Let's start at the beginning.
What did you change to have crank and or water pulley off ?
Old May 29th, 2008, 09:23 PM   #8
Im restoring the car and built a 347 stroker for it, it has been apart for over a year now as ive been working on it.
Old May 29th, 2008, 09:30 PM   #9
Fast
If you went to a 28oz balance from the stock 50oz
then the harmonic balancer is thinner.
I ran into this when I did my 351 swap, as they are 28oz balance also.
Ford Racing makes 3 different spacers to fix this.
I think this is what you need. Summit should sell them. Just make sure
you get the right thickness.
Ford Racing Performance Parts [M-8510-C351]
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old May 29th, 2008, 09:33 PM   #10
I did go to a 28oz balancer I was thinking the balancer was thinner but do not have my old one laying in the garage its in my building stored away.
Thank you very much man.
Old May 29th, 2008, 09:40 PM   #11
Fast
God Help Us
Threads Similar to: Crank pulley
BBR 2.57 Pulley and 10% Overdrive Crank Pulley raycutchins 2005 - 2010 1 May 26th, 2008 06:23 PM
98 crank pulley question 98mustang V6 Mustangs 3 August 16th, 2007 02:56 PM
crank pulley mikedoogen Modular Mustangs 3 June 20th, 2007 01:22 AM
crank pulley help mikedoogen 2005 - 2010 3 June 19th, 2007 01:17 PM
Crank pulley bolt? 88gtstang 5.0 Mustangs 3 March 9th, 2007 10:23 PM
