car wont run
LinkBack (1) Thread Tools
Old May 30th, 2008, 06:28 PM   1 links from elsewhere to this Post. Click to view. #1
gyellow is on a distinguished road
car wont run
well i installed a 5" tach with shiftlight in my car but now the car wont run lol, i ran the tach wires to the back of the fuse block the the green wire from the tach to the negative side of the coil (spliced into the wire) now i go to start the car and it just shuts right off, only stays running while i hold the key completely on. i have heard it could be the relay?? i pulled the tach wire from the coil wire and reconnected the coil wire and it still doesnt work. does anyone think this could be the relay?? and if so where the hell is the relay?? someone please help this is my d.d. lol
1988 lx 5.0 rebuilt motor,t-5 tranny,rear end.
worked heads with an f-cam bbk longtubes, full msd ignition, cold air intake, 3.73's, and suspension work, and fuel pump, soon to be drag car.
Old May 30th, 2008, 08:31 PM   #2
vfast will become famous soon enough
key switch has slide..replace it...about 20 bux from NAPA
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old May 30th, 2008, 08:40 PM   #3
thts it?? does this have to do with installing the tach?? cause it doesnt run right after i installed it lol,
Old May 30th, 2008, 09:01 PM   #4
just could be a one of those things.. but that's your problem takes about 15 mins to replace
6'ers are for kids
Old May 30th, 2008, 09:07 PM   #5
ok kool ill go get one 2morrow so i need the whole key part or just the slider?
Old May 30th, 2008, 09:12 PM   #6
you need the igintion switch..not the key....
this will help
Replace a 1979-1993 Ignition Switch Assembly
6'ers are for kids
Old May 30th, 2008, 09:46 PM   #7
thank you man i appreciate the help big time
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/73549-car-wont-run.html
car wont run This thread Refback June 1st, 2008 01:25 AM
Threads Similar to: car wont run
Car Wont Stay On! Eod 96-98 27 August 28th, 2011 06:58 PM
just rebuilt car and now it wont run.... 99v6stang V6 Mustangs 112 May 6th, 2008 11:52 AM
98 Cobra Wont Run nasty92LX 96-98 6 April 8th, 2008 10:53 AM
Trouble code p0340 car wont run 99v6stang V6 Mustangs 78 January 14th, 2008 01:39 PM
'91 hatch wont run, please help '91 4-cyl hatch 2.3 Mustangs 14 August 9th, 2007 02:08 AM
