351w 302 question
Old May 30th, 2008, 05:49 PM   #1
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
351w 302 question
Question is I heard the blocks were the same block just heads are different deck height. But then in another thread someone said the 351w block can handle more power than the 302. Is this true and if they are the same block then how?
Old May 30th, 2008, 05:57 PM   #2
MIGHTYJO3YOUNG's Avatar
1992 mustang Lx
13.4@ 106
MIGHTYJO3YOUNG is on a distinguished road
i'm pretty sure they aren't the same block, because when doing a swap you have to change out things like intake, flywheel and oil pan. They are just similar.
Old May 30th, 2008, 06:23 PM   #3
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
Think of the 351W as the big brother to the 302.
They are very similar.
They have same lower mounting points and dimensions
i.e. bellhousing bolt patter, motor mount location, ect ect.
The deck height is taller on the 351 giving it a longer stroke and more cubes
This spreads the heads apart and up a little, so lower intakes are wider.
Heads are interchangeable, but the 302 use 7/16 head bolts and the
351 use 1/2"
Stock for stock the 351W block is a good deal stronger than the 302.
The crank and rods are stonger and the casting on the block itself is
beefier in several places.
The 351W is about 3" taller over all and weighs about 100lbs more.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old May 30th, 2008, 07:30 PM   #4
vfast will become famous soon enough
the web is a ton better on the 351...the engine will sit taller but with a set of vert motor mounts will help that
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old May 30th, 2008, 07:36 PM   #5
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
and b oth sexy lol
Old May 30th, 2008, 07:37 PM   #6
dude did you get booted from MF?
351 use 1/2"
6'ers are for kids
Old May 30th, 2008, 09:42 PM   #7
87 Coupe
interesting...thanks for the tidbits of info
Old May 31st, 2008, 08:09 AM   #8
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
Two different blocks altogether. Deck height refers to the distance from the crank centerline to the top of the deck (cylinder bore). There are several variations even in 351 and 302s.
Never fast enough.
Old May 31st, 2008, 08:13 AM   #9
1989 mustang gt
jonboy2389 is on a distinguished road
Send a message via AIM to jonboy2389
damn r.barn you got a 351 twin turbo...shit must screwww, run any times?
Threads Similar to: 351w 302 question
289 and 351W heads on a 302 block? delgadog 94-95 3 June 2nd, 2008 11:02 PM
302 351w notsoslow50 5.0 Mustangs 6 July 26th, 2007 12:14 AM
351w with a 302 crank? 68351w Classic Mustangs 4 July 4th, 2007 12:29 PM
302/347 or 351W OTreborO 5.0 Mustangs 33 December 22nd, 2006 11:10 PM
302 or 351w? lugthug713 94-95 5 November 29th, 2006 02:07 PM
