Discussing Oil Leak in the 5.0 Mustangs Forum. shit.......
Old November 5th, 2006, 10:29 PM   #21
shit....
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old November 5th, 2006, 10:53 PM   #22
On Probation
Tony_90fox's Avatar
are you calling BS, and on what???
MM Sapper Squad
Originally Posted by Regency 2007 View Post
MSO's stupidity has never stopped amazing me since the day he joined this forum.
Old November 6th, 2006, 09:42 AM   #23
Stangzilla's Avatar
i know dude
Old November 6th, 2006, 11:41 AM   #24
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by Stangzilla
I know there are several companies that make the 347 but CHP or Probe industries "same company" Make there own pistons where the oil ring does not intersect the wrist pin where other companies the oil ring intersects the pin causing oil usage and long term reliability issues. I think the bad motor I got was just a fluke. Every company makes a mistake and it just so happened it was on my motor. Coast High Performance made good on the defect and sent me a new motor no questions asked. I would do busniess with them again and also would recommend them to others...
LMFAO!!!!!!! "Make there own pistons where the oil ring does not intersect the wrist pin where other companies the oil ring intersects the pin causing oil usage and long term reliability issues" Number 1, the wrist pin intersecting the oil ring doesn't cause any "oil burning usage issues". And number 2, Probe does make pistons with the oil ring intersecting the pin. I have a set in my engine! Probe makes a 347 piston for a 5.4 rod and an 5.315 rod that way the people that actually believe there are oil control issues due to wrist pin location are happy. Having a short rod will cause you more problems than a pin intersecting the oil ring because the pin centerline is moved lower on the piston. But will probably not cause you any problems. Good machine work and assembly makes a good engine.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old November 6th, 2006, 11:43 AM   #25
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Good numbers though. What does it 60 foot?
Old November 6th, 2006, 06:00 PM   #26
Stangzilla's Avatar
Well whatever it was good enough reason for me to buy one and that is what I read. I was not able to get the 60 foot below 1.71 because of I think the brand new slicks I was runnin. and I am also workin with usin my 2 step on the PMS ya know different launch rpm's and stuff. But I am sure I should be able to get it lower thatn that no?
Threads Similar to: Oil Leak
leak??!!! mustang fanatic 2005+ 15 June 10th, 2008 06:50 PM
leak ! 96gtponyred 96-98 39 September 11th, 2007 05:04 PM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 05:46 PM
Do I have a gas leak? yiplong V6 Mustangs 1 September 6th, 2006 12:23 PM
What is this leak ??? toddman0025 Classic Mustangs 4 August 13th, 2006 02:28 AM
