distributer issue
Old May 31st, 2008, 08:18 PM   #1
89 lx convertable
conrad is on a distinguished road
distributer issue
i was told that the rod that goes into the distributer and the oil pump was to be installed in the oil pump first. i went to prime up the oil pump and couldn't get the rod to set down in the pump.if this is true, is there any way to install it through the top instead of havin to pull the engine out and droppin the oil pan.i hope there is because thats all i got left to do to fire it up for the first time in 2 years.
Old June 2nd, 2008, 01:55 AM   #2
65 B/FX is on a distinguished road
First, take the lock ring off the rod with a set of pliers. Then install the rod in the distributor end first with some loc-tite. This will hold the rod in place on the dist as you drop in the dist and mate the rod to your oil pump. It works great for your situation. Did it last week and everything is doing fine.
1964 Falcon Sprint 4 speed
1965 347 Cyclone 4 speed, B/FX clone
1993 Mustang Cobra (red/grey cloth)
Old June 2nd, 2008, 12:38 PM   #3
89 lx convertable
thanks man ,i'm giong to try that out
Threads Similar to: distributer issue
Distributer Problems! black95conv 94-95 30 January 30th, 2008 10:31 PM
here is my issue bigbadwollfff04 Drag 35 July 5th, 2007 09:34 PM
t5 issue 342stroker 5.0 Mustangs 3 June 4th, 2007 09:41 PM
Distributer cap HMUSN 5.0 Mustangs 2 May 8th, 2007 04:50 PM
