Sagging Door
Old May 31st, 2008, 09:33 PM   #1
1988 Mustang GT
Corey is on a distinguished road
Sagging Door
My 1988 GT drivers door has been sagging for a while now. I ordered new pins and bushings and plan to put them in when I get them. Should this fix the problem or is it common for the hinge to also need replacing?
Old May 31st, 2008, 10:13 PM   #2
ThrashN's Avatar
91 LX 5.0
11.87
ThrashN is on a distinguished road
That should fix the problem
Penn Mustangs
Old May 31st, 2008, 11:32 PM   #3
1988 Mustang GT
Thanks.
Old May 31st, 2008, 11:55 PM   #4
ujslost's Avatar
That should fix it up man!
I suggest taking the doors and hinges off the car to do it.
I will tell you they arent that fun. I had to cut my pins in half with a die grinder cause they were bent I guess. Anyhow they wouldnt knock out.
Old June 1st, 2008, 12:55 AM   #5
demonicus's Avatar
1988 mustang LX coupe
demonicus is on a distinguished road
just remember that the doors do unbolt from the frame completely. I dont know why but we have alot of bodymen out here that seem to think the hinges are welded on.
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars
88coupe- lookin for a new powerplant
Old June 1st, 2008, 01:00 AM   #6
ujslost's Avatar
yep, 3 bolts per hinge, easy to get to if fender is off, and makes aligning the door alot easier
Old June 1st, 2008, 01:54 AM   #7
ryans88gt's Avatar
The hinges have some sealant on them that looks to the untrained eye like they are welded to the door post. The stock pins have to be cut out. I have a set of pins and bushings from 5.0 resto that I am not using if anyone needs them.
Old June 1st, 2008, 03:37 AM   #8
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
My drivers door is doing the same thing.
How much are you looking for ($) the bushings and the pins??
1990 lx coupe
Old June 1st, 2008, 03:09 PM   #9
ryans88gt's Avatar
1990 lx coupe
PM me
Old June 1st, 2008, 06:50 PM   #10
ujslost's Avatar
Local parts stores have them for like $7 each or so.
Old June 1st, 2008, 08:24 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old June 2nd, 2008, 01:10 AM   #12
1988 Mustang GT
I checked the local stores and no luck. I found the pin and hinge for $13 on e-bay. My passenger door is fine so I should be alright with just the drivers door. Is it pretty tough getting the fender off?
Old June 2nd, 2008, 02:47 AM   #13
ThrashN's Avatar
91 LX 5.0
11.87
You don't need to remove the fenders to install the pins. Cut out the old pins with a dremel (get alot of cut-off wheels). When you cut the pins cut them like you're chopping down a tree (so the cut looks like this <). Also when you cut the bottom pin, cut it as close to the bottom as you can. Because of the way the door curves it will be easier to get out that way. Once the pins are cut use a punch and a hammer to knock them out, replace the bushings put in the new pin and you're done. You Will want some one to help you with the door when the pins are out. Use a floor jack to help support the doors.
Penn Mustangs
Old June 2nd, 2008, 04:36 AM   #14
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
1979 -93 Door Hinge Pin Kit with Bushings - Fox Mustang Restoration
there ya go $7.50 per door
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old June 2nd, 2008, 12:59 PM   #15
1988 Mustang GT
Thanks for all the help.
Old June 2nd, 2008, 01:27 PM   #16
ryans88gt's Avatar
yeah I have the $25 kit from 5.0 resto that is both doors and the rollers and roller pins if someone wants it. $15+shipping
Threads Similar to: Sagging Door
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 25 April 26th, 2011 01:49 PM
door whitemustang02 Visual 16 June 1st, 2008 06:24 PM
sagging doors - 2002 GT eschober Visual 2 August 23rd, 2007 09:04 PM
door mustang1072 V6 Mustangs 6 August 19th, 2007 03:09 AM
door need help wadepetersen V6 Mustangs 8 July 3rd, 2007 10:45 AM
