4 eye steering wheel loose?
LinkBack (1) Thread Tools
Old June 1st, 2008, 08:19 PM   1 links from elsewhere to this Post. Click to view. #1
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
my steering wheel was incredibly loose and shaky. so, i started taking stuff apart to see if i could find out why.
this is a really simple fix and it took me about 10 minutes.
first thing to do is remove the dash piece in front of the instrument cluster. it's only a few screws in the top.
you also need to remove the piece under the steering column. (4 phillips heads)
next, remove the ring around the steering column, just behind the wheel. just pull it out to the left as shown and it pops right off.
remove the steering column cover pieces by removing 5 screw from the bottom. (3 on the right, 2 on the left)
remove the blinker switch assembly. you don't need to take the harness off of it, unless you want. it's held on by two T-20 screws.
then, remove the wiper switch. held on by 2 phillips screws. again, you don't need to remove the harness before unscrewing the switch. once it's off, it will just hang out of the way.
once the wiper and blinker switches are out of the way, simply tighten the 2 13mm bolts shown in the picture.
put everything back in reverse.
like i said, shouldn't take you more than ten minutes. and, your steering wheel will have a much more solid, sturdy feel.
i have no mustang. so don't listen to anything i say.
Old June 1st, 2008, 09:51 PM   #2
Trans Am WS6
ThreeHonks302 is on a distinguished road
Send a message via AIM to ThreeHonks302
this happened to me a while back... nice thread
Old June 1st, 2008, 10:20 PM   #3
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
i'm sure you didn't somehow break your speedometer needle off while doing this though. (look at the pics)
how the hell i did it.... beats the crap out of me.
Old June 2nd, 2008, 05:22 AM   #4
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Just did this the other day on my fox for the second time.
Old June 2nd, 2008, 12:03 PM   #5
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
I had the same problem a little loctite will fix it
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/73862-4-eye-steering-wheel-loose.html
A Few Loose Screws » Blog Archive » 4 eye steering wheel loose? This thread Pingback June 5th, 2008 08:55 PM
Threads Similar to: 4 eye steering wheel loose?
steering wheel terribleonexx88 5.0 Mustangs 2 March 17th, 2008 08:33 PM
Steering wheel scxc15 V6 Mustangs 3 October 15th, 2007 01:31 AM
Loose steering Veeder 99-04 0 July 24th, 2007 10:31 AM
Steering wheel help... TurboLX General Tech 0 June 10th, 2007 04:19 PM
loose steering theodoor24 Classic Mustangs 4 October 19th, 2006 11:53 PM
