Discussing Building a 500hp notchback in the 5.0 Mustangs Forum. But forgot to mention, if it can be done for 5-$6000 like some are ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
But forgot to mention, if it can be done for 5-$6000 like some are saying then thats great, put the extra money into beefing up the tranny. Also is the stock axle going to be good enough for this or do i need to toss that?
#22 |
1987 ford mustang gt
well see when shes done
if you are doing an aftermarket block you might be able to do the bottom end for 4,000 including the block.
#23 |
1989 LX Vert - 1993 Notch
Fast
Here's what I'd do. ...........
Get a built 306 short block from Fordstrokers.com and request it be made on an "early vintage" or "mexican" block. They are strongest of the "stock" blocks. Will run you about $2,000. Get a custom head/cam package from camshaftinnovations.com run you about $2,000 Tell both those guys what you're doing and they will get you the right set-up. Then get a turbo kit from Quicktime for about $3,000 Another $1-2,000 on stuff like Holley Sys II intake and injectors, MAF, ect. You will easily meet your goals and have a rock solid power pack.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
#24 | |
#25 |
1988 lx 5.7
11.6@109
if u have 8k to put into a motor now go and get the boss,dart or manowar block then you can do a high reving turbo 347 stroker.
you will proly be well over your 500 hp goal but u can decrese the boost and timing.
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331 MILITARY CREW USAF LUKE AFB AZ, E-5 SELECT 7995 AMMO I.Y.A.A.Y.A.S |
#26 | |
Fast
If he goes with a Dart 347 running a turbo he will be making 600-800rwhp. ....... overkill for what he wants
#27 | |
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
#28 | |
Asshole™
1990 Mustang LX
9.36@143 mph
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#29 | |
1988 lx 5.7
11.6@109
#30 |
^ + fast NA cars make super fast FI cars
#31 |
my goal of 500hp was because im not sure on how far one can go for steetable and pump gas.
If i can hit 650-700hp and still be streetable and use pump gas then sure! lol. I just want sure what i could get for an $8000 price limit and still be realistic. So i have a few options by the sound of it, but still a few unanwsered questions. Options so far is a 306 mexican block, custom heads and cam with a single turbo kit Or a 347 dart block with a turbo or a 351w n/a setup Now my questions. Tranny, will a beefed up T-5 be sufficient? Also the stock axle, can it handle this type of horsepower? Im not looking for a car to do wheelies down the track, but in order to make a decent pass down the track with a car making this horsepower, im going to need a good pair of drag radials which means i will need an axle to hold it together. Can the stock Axles handle this kind of power with drag radials? I appreciate all the help so far guys, i find it much easier to have an idea of what to get before i have the car. The color im torn between a deep red pearl or a deep blue pearl. I was at mission raceway watching the races the other day and seen a car with a really deep red that almost looked black from far away until the sun hit it and it was almost like a candy apple/laser red. Paint will come first so i dont have a half ass looking paint job with a different color engine bay compared to the rest of the car, get it painted with the car gutted. Last edited by _UnLiMiTeD_ : June 2nd, 2008 at 08:48 PM. |
#32 |
1979 mustang 5.0
hopefully 11's when complete
Well another option is use a 351w block. They have beefier mains and thicker webbing. People say they hold up to 600hp with issues. In order to run a 351 you need a different oil pan and headers. A 351w also has a different intake manifold, oil pump, distibuter and obviously internals. Basically the deck height of the cylinders is a little taller that a 302 block.
I think this is the way to go cause it's WAY cheaper than getting an aftermarket block you'll need a tremec transmission
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO Last edited by built351w : June 2nd, 2008 at 09:57 PM. |
#33 |
yea i had 351 as an option. Im almost leaning towards a turbo setup mainly because then i have that room to go higher with hp later on if i decide to. I dont know, theres some real nice options to play with its so hard to decide what i want.
still no anwser about using the stock axle though Last edited by _UnLiMiTeD_ : June 2nd, 2008 at 10:22 PM. |
#34 | |
Dart: Ford Iron Eagle Sportsman Blocks or Dart: Ford Iron Eagle Blocks not to be an asshole but they both look less than 4000 to me (including finishing work) but on a side note, if you willing to go with a 351w then i'll change my vote to that |
#35 |
1988 lx 5.7
11.6@109
if u stay with the 302 based block a beefed up t-5 will hold it but the torque of a 351 will need a stronger tranny. also the stock axels should be fine just get a good set of gears. if it aint broke dont fix it.
#36 |
1988 lx 5.7
11.6@109
i think a 408 stroker with some AFR 225's an edelbrock efi spyder intake and a tremic transmission. 10.5:1 compression and some 91-93 octaine coustom grind cam and you will have one hell of a car.
#37 |
so no power adders then? lol
I should start a poll with all the motor choices you guys have given me and see which one wins 351w N/A 408 Stroker N/A 306 S/C or Turbo 347 Turbo or N/A Remember with all these motor choices i still want A/c, power steering and pump gas. Also if you can hit over 600hp on pump gas why do some use race gas at these horsepower levels? Last edited by _UnLiMiTeD_ : June 2nd, 2008 at 10:34 PM. |
#38 |
1983 mustang lx
408 ftw
#39 | |
Asshole™
1990 Mustang LX
9.36@143 mph
Because its easier. Alot of people would rather tune for the most power on race fuel than to try to tune high power levels that run safely on pump gas. Some tuners don't know how either.
#40 |
Well gas is already high enough so i dont find it worth it go use race gas when i know it can done on pump gas anyways.
I love all the motor options but hate them at the same time because they all sound awesome. N/A maybe harder to tune to hit 500+hp on pump gas dont you think? Or am i way off on that |
Threads Similar to: Building a 500hp notchback
| 500hp | OcOnnor220 | 4V / SVT | 19 | April 26th, 2008 01:37 AM |
| im building a notchback | venom_srt8 | 5.0 Mustangs | 131 | August 28th, 2007 06:21 PM |
| HELP! my 500hp gt putts | chk2711 | 99-04 | 8 | July 13th, 2006 04:43 AM |
| For those making 500hp + or not | demononwheels | Suspension | 12 | July 9th, 2006 08:45 AM |
| what clutch for 500HP | 03stanger | 99-04 | 4 | June 12th, 2006 07:21 PM |
