Tranny Problem
Old June 2nd, 2008, 08:50 AM   #1
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
Tranny Problem
88 mustang gt equipped with a t-5 transmission. At slow speeds, even moderate the gears shift fine (they are a little difficult to get into) But when i am all over the car shifting into second usually makes all kind of wicked noises and just pops out of it. I just put on the mgw short throw shifter but i wasn't really driving it before that, so i dont know if that is the problem. So second gear grinds, only on hard acceleration. What am i to do?
Old June 2nd, 2008, 11:13 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Does the shifter have adjustable stops? If so I'd make sure they are adjusted properly first but it sure does sound like you have some syncros going bad and possibly a input shaft bearing as well.
Old June 2nd, 2008, 11:22 AM   #3
hopper is on a distinguished road
if it grinds going into gear, try this-put in the clutch to take it out of first-let the clutch back out while in neutral-press the clutch again to put it now into second.try this at different speeds, if the bouble clutching fixes the situation then you know there are syncro problems in the transmission.
Threads Similar to: Tranny Problem
Tranny problem. o.O MustanG_guy17 V6 Mustangs 11 April 13th, 2008 09:33 PM
another tranny problem 00gtCoolGuy 99-04 1 January 4th, 2008 09:29 AM
tranny problem? ZoomZoomMFer 96-98 16 August 23rd, 2007 08:51 PM
T-5 tranny problem BGooch 5.0 Mustangs 4 August 14th, 2007 09:37 PM
tranny problem Mustang RacR94 V6 Mustangs 3 April 2nd, 2007 12:08 AM
