Something stinks
Old June 2nd, 2008, 03:20 PM   #1
2002 V6/1967 Mustang
JasonMarshall is on a distinguished road
Something stinks
OK, so I have added a 91 LX 5.0 to my list of cars. Since I have picked it up on Thursday, I have been getting a strong antifreeze odor on the outside of the car. There are no seen leaks, I verified today that there is not a blown head gasket with a chem test of the antifreeze. Anyone have any idea's? I originally thought it was a blown head gasket because I thought there was oil in the radiator and it misses at high rpms. But now that we have checked that...... I'm clueless!
2002 V6 Mustang/ 5 Spd, cold air, flowmaster exhaust, Hedman Headers
1991 LX 5.0 Convertible, Flowmaster 40's
1991 LX 5.0 Hatch, offroad h pipe, Flowmaster 40's 3.77's with a locker
Old June 2nd, 2008, 03:23 PM   #2
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
ok so explain exaclty how you tested it, i recommend a cylinder leakage test cause that does sound alot like a blown head gasket
Old June 2nd, 2008, 03:25 PM   #3
A buddy that has a garage chem tested the antifreeze for oil. Its much faster than a compression test. All he has to do is pull some antifreeze from the radiator and place it in a chem solution that changes color if there is any trace of motor oil.
Old June 2nd, 2008, 03:31 PM   #4
78mach1's Avatar
yes i understand the way it works, i use one that pulls co2 out of the antifreeze. but that doesnt mean its completely accurate.
just do a quick cylinder leakage test and that will tell you 100%
Old June 2nd, 2008, 04:51 PM   #5
sixpack's Avatar
91 lx vert
sixpack is on a distinguished road
+1 on the cylinder test i would think that is a blown head gasket my dads truck was like that and there wasnt any oil in the antifreeze but it did have a blown head gasket
If you aint breaking parts your not going fast enough
Old June 2nd, 2008, 07:44 PM   #6
fogged306's Avatar
89 GT
Check your oil and see if it looks like a milkshake.
Old June 2nd, 2008, 08:03 PM   #7
91cobra5.0's Avatar
98 Cobra
HEATER CORE, mine was like that too but i could smell it inside also and it would smoke twoards the very end before i replaced it
Old June 2nd, 2008, 09:39 PM   #8
Nope, not that I can see anyways....
Old June 2nd, 2008, 11:35 PM   #9
ujslost's Avatar
have the coolant system pressure tested that will show where the leak is for sure.
Old June 3rd, 2008, 07:50 AM   #10
So far I have yet to be able to tell if there is a leak..... I have no antifreeze or oil for that matter on the driveway. I haven't had to add any fluids at all either.
Old June 3rd, 2008, 07:55 AM   #11
hopper is on a distinguished road
sounds like a small crack in the heads or head gasket. Sometimes there is just a trace amount that seeps through either one of these mentioned cracks, and is burnt throuout combustion. do a system pressure test, then pull the plugs and look closely for foweling or moisture on the tips, while you are there do a cylender check. I have encountered this before. hopefully you do not have a cracked cylender.
Old June 3rd, 2008, 08:41 AM   #12
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
I'd put $100 on it being the heater core.
Common.
Check drain hole on passenger firewall.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old June 3rd, 2008, 01:43 PM   #13
78mach1's Avatar
Common.
but that doesnt explain the intermitant miss fire
Old June 3rd, 2008, 01:54 PM   #14
ujslost's Avatar
no but a head gasket would ! so check cylinder for water and water coming from tailpipes
Old June 3rd, 2008, 02:05 PM   #15
78mach1's Avatar
yep
do i have to say it agian...........CYLINDER LEAKAGE TEST
that wiill tell you all
Old June 3rd, 2008, 03:52 PM   #16
ryans88gt's Avatar
Could be that the previous owner spilled some antifreeze... That smell hangs around for a little while.
I have never had a blown head gasket smell like antifreeze...lol If it is leaking antifreeze, you'll see it eventually and the level should be going down.
Intermittent missfire? Could be any number of things. First thing to do when you get a car like this is a leak down test and compression check.
Threads Similar to: Something stinks
Running Really Rich. It Stinks TWallace 5.0 Mustangs 3 October 26th, 2006 11:45 AM
