Please Help Roller Rocker And Valve Adjustment Sequence
Hey there, I just put new trick flow twisted Wedge Heads on my 1992 gt and I'm about to install 1.6 trick flow stud mounted roller rockers. I pulled up the valve adjustment sequence from my school and I just wanted to make sure this was right if I was doing stud mounted rockers or how all of you guys did yours, thanks.
5.0L HO Valve Adjustment Sequence Crankshaft position____ Intake Valve____ Exhaust Valve No. 1 Cyl. At TDC_____ No. 1,4,8________ No. 1,3,4 Rotate 360 degrees___ No. 3,7__________ No. 2,6 Rotate 90 degrees____ No. 2,5,6________ No. 4,5,8 |
Threads Similar to: Please Help Roller Rocker And Valve Adjustment Sequence
| rocker adjustment | thethirdmurph | 5.0 Mustangs | 24 | May 2nd, 2008 03:54 PM |
| rocker/valve lash adjustment | Hunt_chevs | 5.0 Mustangs | 5 | March 25th, 2008 02:55 AM |
| roller rocker valve lash adjustment | Red Hot 92 | 5.0 Mustangs | 7 | May 19th, 2007 11:51 PM |
| Valve Cover/Roller Rocker Question | 5-0stank | 5.0 Mustangs | 11 | March 13th, 2007 09:43 PM |
| Smog Equipment and Roller Rocker Adjustment | RMBillings | 5.0 Mustangs | 2 | November 27th, 2006 08:15 PM |
