1994 Mustang GT
good H/C/I combos
I want peoples opinions on the best H/C/I setup
![]() Mac CAI, flowmaster 40-series mufflers, Steeda shortthrow shifter, Mac O/R H-pipe |
1988 Mustang GT Vert
Trick Flow Track Heat Heads, Holley Systemax II Intake, and a custom cam...
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon... |
1994 Mustang GT
I was thinking gt-40 heads, trickflow track heat intake and E-cam. Or is that a bad setup?
gt-40 heads dont flow nearly as good as the trick flows and the e cam is outdated but would work good with your combo... but you would get alot more power out of my combo...
Endless possibilities. How much money do you have to spend and how much horsepower are you looking to make?
98 Cobra
what does HCI stand for? from what you guys are calling about it looks like heads? cam? intake?
if thats the case trick flow has a package deal for 2400 staring twisted wedges
1983 mustang lx
98 Cobra
#9 | |
1986 mustang gt convert
edelbrock makes great power,they have a new roller cam for the rpm set up...i had 10.5 comp and edelbrock 60259 heads,kd 150 domes,and roller rockers,xe comp cam,rpm intake and made 387 hp atfly...trick flow is nice just you are limited on ya heads with the twisted chambers,no domes, but are great.....rhs heads are good,for the $ world has great heads and make good power without emtying ya pockets..ford cams are ok but outdared get better with comp,crane,insky,erson ect..
93 GT N/A 302 H/C/I
6.73@101.7--- 10.59@126.06
Two thumbs up for the TFS lineup. Easy 300+ to the tires with the stock short block.
N/A 302 Pushrod Power ![]() |
1994 Mustang GT
Afr heads are also very good
I have seen quite a few 300+ rwhp numbers with afr heads
1994 Mustang GT HCI N2O yada yada yada http://www.cardomain.com/id/bigshirtlesspete |
there are plenty of good heads (afr, canfield, trickflow etc...) same with intake and cam, but it's like darrell says every single time, how much do you want to spend and how fast do you want to go
that x cam sounds mean.
ive got the similar question. money aint a thing. i want 450+ to the rear wheels. im thinking. probably will be a 331 or even a 351w,stroked and forged. cams with a .600+ lift and a .300+ duration. afr 185cc heads. victor jr intake. what ya think? i want a torquey beast.
98 GT summer toy. 05 FORD explorer Daily Driver. See Garage For Mods. the wheels of his mustang exploding on the highway like a slug from a 45. TRUE DEATH. 400hp of maximum performance piercing the night. this is black sunshine. Last edited by truedeath; June 3rd, 2008 at 06:42 PM. |
#16 | |
i would go the 351w stroker route, no replacement for displacement |
Here are some more idle videos.
This is the stage 2 Trick Flow cam. Please disregard the messy generic spark plug wires. When plug wires are on back order you have to use what you have laying around... This is an AFM N-71 cam. At the end of the video you can here the idle. I had a few more but I can't find them.
#18 | |
![]() just wondering if there was anything else i should look at. ive been through 3 blueprints for a swap and think ive settled with the tried and true pushrod motor. these mods are just too damn expensive to build up with half the gains of a pushrod.
98 GT summer toy. 05 FORD explorer Daily Driver. See Garage For Mods. the wheels of his mustang exploding on the highway like a slug from a 45. TRUE DEATH. 400hp of maximum performance piercing the night. this is black sunshine. |
#19 | |
I buy alot of shit from him. He is very knowledgeable and is a hell of a nice guy.
#20 | |
Threads Similar to: good H/C/I combos
| header and mid pipes combos | 00gtCoolGuy | 99-04 | 5 | January 7th, 2008 10:39 PM |
| Possible Combos | RandoGT | 96-98 | 11 | October 10th, 2007 08:14 PM |
| New Color Combos on Roush 427Rs | Pastor J | 2005 - 2010 | 7 | September 10th, 2007 02:14 PM |
| Good Carb Combos.. | StangAddiction | 5.0 Mustangs | 28 | April 2nd, 2007 03:03 PM |
