1993 Mustang LX Vert
Check oil light
How often do you have to add oil after an oil change or do you have to add between oil changes??? I just built the 306 700 miles ago.
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer |
it shouldn't be burning oil in the first place.
1983 mustang lx
+1 a fresh motor like that shouldnt be using any. how long does it take to burn a half/whole quart of oil
dont try this because i hated my motor, but in the old 5.0 i let it run down 4 1/2 quarts of oil before id add any and it ran till the day i pulled it out. had 263,000 original miles on it! |
1992 Mustang GT
Coming soon...
Car has 120k and doesnt burn a drop.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work |
So what do you guys think could cause this???
1992 Lx
11.39@119.24
leak?
not burn but a little blow by is possible
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
maybe the rings didn't seat? Or you are loosing oil somewhere. Check coolant, and the ground where you park the car.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1983 mustang lx
park your car on some pavement, or put a piece of cardboard under your engine over night after you finished driving it and see if it leaks externally.
No leaking nowhere, nothing in the coolant.
My 1991 has been using a quart every 1500 miles with conventional oil and about every 1000 miles with synthetic since it was brand new up until I had about 145K. I have no idea how much now because I've only put 10K on it in the last 10 years and it gets changed by time now and not miles.
does it smoke at all, on start up, or under WOT. Have someone follow you to tell you, cause you can rarely see it from inside the car.
I have seen it smoke out the exhaust. I was going down the road a stopped to get some beer came back out and started the car and it smoked for a second and then went away.
Ryan, any ideas???
#15 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Mine only seems to burn oil when I stomp on it and run 3000-5000 rpms all the time
Threads Similar to: Check oil light
| Check Engine Light HELP??? | soccerboy08 | V6 Mustangs | 6 | February 22nd, 2008 01:24 PM |
| Check Engine Light On | Geezer | 2005 - 2010 | 5 | July 23rd, 2007 10:42 AM |
| Check oil light on | dr.gonzo! | 5.0 Mustangs | 9 | May 31st, 2007 04:34 PM |
| Check Engine Light? | GreenFaleen | V6 Mustangs | 13 | November 20th, 2006 03:26 AM |
| Seriously need Check engine light help!! | jsteves1313 | V6 Mustangs | 4 | November 5th, 2006 03:24 PM |
