88 Mustang GT
upgrading fuel injectors... need help
im upgrading my fuel system. i plan on gettin ev6 24 lbs. injectors and adaptors, steeda fuel rails, steeda fpr, and c&l trueflow intake pipe. has anybody used the steeda fuel rails? what do i need to fit it to my stock fuel lines and do they come with an attachment for the fuel pressure regulator? and with the intake pipe i just use the stock mass air sensor but would it be better to get a 93 cobra computer or just chip the a9l and call it a day?
The Steeda fuel rails will not work with the stock fuel hard-lines, so you'll need to change them out, along with the fuel fittings. Also, the fuel rails dont have provisions for a "rail" mounted fuel pressure regulator, so you'll need a remote style.
You can run the stock mass air with the C&L. No sense in getting a cobra ECU, the factory A9L is fine. Get a chip burned, and you'll be good to go.
1992 Lx
11.39@119.24
i have a cobra computer, 24lb injectors, cobra maf and tb and my car runs perrrrrfect
#4 | |
1994 Mustang GT
+1 there is no point in upgrading the fuel rails unless you have some crazy modifications planned
1994 Mustang GT HCI N2O yada yada yada http://www.cardomain.com/id/bigshirtlesspete |
#6 | |
I read between the lines. He stated 24lb injectors so we know he isn't planning much so the fuel rails are not needed.
the 94-95 rails are a tad larger you can go with them
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
I was giving him the benefit of the doubt. Your probably spot on though, as you nearly always are.
Threads Similar to: upgrading fuel injectors... need help
| 19 lb/hr fuel injectors | lilgreenstang | 2.3 Mustangs | 2 | May 3rd, 2008 09:56 PM |
| Fuel Injectors | Mach Boy | 99-04 | 3 | November 7th, 2007 08:32 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| fuel injectors | scubasteve041186 | V6 Mustangs | 7 | January 24th, 2007 02:44 AM |
| Fuel Injectors | RC02GT | 99-04 | 3 | October 9th, 2006 07:44 AM |
