LinkBack (1) | Thread Tools |
#1
1991 lx
need 5 lug conversion and wheel help
i'm putting 5 lug axles on my 91 lx and was wondering if i can bolt on drums and rotors from any other vehicle with no modifications. i also plan on using weld draglite rims and was wondering what the max size width rim i can use without mods(no quad shocks)on the rear and what back space. some tell me use 8 inch, some say i can use 10 inch width. mt street radial will be the tire of choice. what size tire on witch rim would be best fit. thanks for the help
1988 mustang LX coupe
why get drums and rotors? go with a rear disk kit. SN95 hardware should bolt right up
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars 88coupe- lookin for a new powerplant |
1995 Cobra & 2003 GT
the only direct bolt up you can do for the 5 lug is up to 95 and almost any rim will fit just ont get the tire to big
mustang depot sells a fairly cheap kit with yukon axles.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1992 Lx
11.39@119.24
why go 5 lug if youre gona put those rims?
#6 | |
If you are still stuck on converting, here is what you need: Front - 85-91 Lincoln Mark VII rotors, 84-86 SVO Mustang front rotors Rear - '83-'92 4 cylinder/3.0 V6 Ranger/Bronco II left (driver) side axle or '86-'97 Aerostar right (passenger) side axles and drums
1991 lx
thanks for the info you have been a big help
I'd much rather pay the 1200 I did and have the parts I got on.
95 spindles (swap ball joints to SN95's) 99 PBR 2piston calipers (from any mustang V6 or GT 99-04) 98 8.8 with disk brakes and 3.73gears (got lucky with the 3.73s in there) but for a full stock setup I'm guessing you could grab it for less then 800 Works mint and stocks on a dime giving you back some change.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/74197-need-5-lug-conversion-wheel-help.html
| need 5 lug conversion and wheel help | This thread | Refback | June 9th, 2008 12:07 AM | |
Threads Similar to: need 5 lug conversion and wheel help
| Five Lug Conversion! | Olita 1 | 5.0 Mustangs | 23 | December 26th, 2007 10:35 AM |
| 5 lug conversion | BWAL | 5.0 Mustangs | 15 | September 16th, 2007 05:09 PM |
| 5 lug 4 wheel disk brake conversion | etony89 | 5.0 Mustangs | 3 | July 21st, 2007 10:48 PM |
| 5 lug conversion | 1990CA50 | 5.0 Mustangs | 2 | January 3rd, 2007 03:30 PM |
| 4 lug to 5 lug conversion questions | jharp59 | Classic Mustangs | 0 | June 10th, 2006 10:44 PM |
