No Electrical forum?
Old June 4th, 2008, 05:19 PM   #1
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Anyways, not sure if its the right spot, but move if needed. Anyone have or know of a website where I can find the wiring diagram for the horn on a 88 GT? My horn isn't working so I decided to check the fuses and sure enough the fuse that goes there isn't there. So I pulled out the proper amp fuse from another location and put it in its spot. As soon as it contacted the metal the horn sounded. Just as I suspected. Either the owner before me was to cheap to have it fixed or it was another way for a hillbilly redneck mechanic to fix the problem.
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old June 4th, 2008, 05:24 PM   #2
1992 Lx
11.39@119.24
ive yet to see a foxbody whos horn works
Old June 4th, 2008, 05:36 PM   #3
1988 Mustang GT
N/A
Well I'm working on. Once I put the fuse in, it sounded soooo damn weak but got better. I wonder if it scared the shit out of whatever might be in the horns (if anything) lol
Old June 4th, 2008, 08:00 PM   #4
fogged306's Avatar
89 GT
Most likely its your switch. All the switch does is make contact with ground when you push it. Either the clock spring went bad and grounded out or the switch is just permenantly touching metal. I would pull it apart and have a look.
...and there is an electronics forum in the general tech section.
Old June 4th, 2008, 09:14 PM   #5
1988 Mustang GT
N/A
The first place i'll look is the switch. Wheres that located?
Old June 4th, 2008, 10:13 PM   #6
fogged306's Avatar
89 GT
In your steering wheel itself. I've never had a stock wheel on my car so I don't know what they look like or how they come apart.
Threads Similar to: No Electrical forum?
Electrical Help JDMILLS Classic Mustangs 3 March 7th, 2008 07:48 PM
electrical help bobb17 2.3 Mustangs 10 February 10th, 2008 11:27 PM
Electrical help... joeice14 2005 - 2010 8 January 30th, 2008 01:34 AM
Need Electrical HELP!!! monkey187 Audio/Video 8 March 19th, 2007 10:41 PM
Electrical Issue wilburgtwoot Audio/Video 3 February 19th, 2007 10:52 AM
