adding trans fluid to t-5
Old June 5th, 2008, 04:10 AM   #1
fastford3388's Avatar
1991 Mustang GT
fastford3388 is on a distinguished road
Send a message via AIM to fastford3388
how do i add trans fluid to my t5? just pour it in the opening for the shifter? also, how much to fill one of those bad boys? i heard 2.5 quarts? anyone know for sure?
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
Old June 5th, 2008, 04:15 AM   #2
bullitt5576's Avatar
2001 Bullitt
bullitt5576 will become famous soon enough
on the 3650 and t45(IIRC) there is a filler plug on the tranny and you are supposed to fill untill it drips out (according to the haynes manual, hopefully that helps on your transmision too
MM NEW EDGE COBRA CREW #2
Old June 5th, 2008, 04:53 AM   #3
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
I've heard that you can fill it through the shifter (taking it off of course, but you know what i mean).
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old June 5th, 2008, 04:59 AM   #4
2001 Bullitt
you can you can do that also, but you have to take off the trim piece, the rubber boot, the shifter, clean the silicone off, fill it, re apply silicone, put the rubber boot back on, and put the trim on, and keep track of how much you put in, its convient if your putting a new shifter in but i would probably just use the fill plug on the tranny
Old June 5th, 2008, 09:40 AM   #5
e3sean's Avatar
1988 lx
9.68@142
man why dont u just pm me for these questions? lol
i told u 3 quarts you can fill it from the shifter housing or from the fill plug (the top 3/8" dirve ratchet plug) just make sure u put a smalll bead of silicone around the shifter housing when u put the shifter on.
<font size=4><b>MILITARY CREW
Old June 5th, 2008, 09:42 AM   #6
e3sean's Avatar
1988 lx
9.68@142
that is right if u dont know how much is in there already but i just sent him that tranny and its empty so its exactly 3 quarts.
Old June 5th, 2008, 09:44 AM   #7
e3sean's Avatar
1988 lx
9.68@142
did it get there safely? how did the box look? it wasnt a typical trans box i had to kinda ghetto rig the box.
Old June 5th, 2008, 11:35 AM   #8
1991 Mustang GT
sean i got it safely and all looks good! it looks amazing. i should have it all put together next week and we shall see how she runs. thanks alot for building that up for me!
Old June 5th, 2008, 12:49 PM   #9
e3sean's Avatar
1988 lx
9.68@142
no problem man glad to help. make sure u get a pro 5.0 for that beast
Old June 5th, 2008, 01:49 PM   #10
ryans88gt's Avatar
So, I always leave the fill plug out when I am filling it. I am not good at counting, plus I buy my DexIII by the gallon...
BTW, make sure the driveshaft is in before you fill it.
Old June 5th, 2008, 02:21 PM   #11
e3sean's Avatar
1988 lx
9.68@142
i dont remember if i put the shipping plug in that one or not if there is a little black gromit where the deiveshaft goes u can fill it before u put it up then just push the yolk on.
Old June 5th, 2008, 02:23 PM   #12
e3sean's Avatar
1988 lx
9.68@142
ya if u have fluid in it then pull the plug out but since he didnt have any at all its exactly 3 quarts so he should just count it and leave it in if he is on an uneven surface then it might prematurely come out of the hole.
Old June 5th, 2008, 02:55 PM   #13
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
Instead of taking shifter off ....................
It's MUCH easier to simple run a clear plastic tube from home depot
down thru the engine bay to the top fill plug.
Stick hose in hole and fill from engine bay.
Remove hose and reinstall plug.
No mess and a LOT easier than taking your center console apart.
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old June 5th, 2008, 03:00 PM   #14
ryans88gt's Avatar
Easier than that is to get the 1 qt squeezy bottles and a 8-12" length of 3/8" fuel hose. Push the hose over the end of the squeezy bottle and put the other end in the fill plug and squeeze.
Old June 5th, 2008, 06:35 PM   #15
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
or go get a fluid pump that always worked out great for me it only cost like 8 bucks too
Old June 5th, 2008, 06:36 PM   #16
Fast
That always made a mess when I try something like that ...... lol
God Help Us
Old June 6th, 2008, 04:00 AM   #17
1991 Mustang GT
thanks guys but the trans is going in so i think ill just fill it through the shifter since the console is already torn apart and there is no shifter on it yet. thanks for the heads up on the drive shaft, ill put that in first. i definitely would have poured it all over the floor had i not known that. some leakage is normal even if i have the driveshaft in and on level ground???
Old June 6th, 2008, 04:17 AM   #18
e3sean's Avatar
1988 lx
9.68@142
easier then all of that is just to fill it before he puts it in cause i am pretty sure i put a shipping plug in it so it wont pour out the back and all he has to do is slide the yolk on when its in there and no fluid will leak out
Threads Similar to: adding trans fluid to t-5
Trans Fluid Change 90Stang 2005 - 2010 0 March 10th, 2008 10:55 PM
adding auto transmission fluid retired jim 2005 - 2010 3 March 16th, 2007 12:33 AM
What Kind Of Trans Fluid For A T45 wolffer 96-98 2 September 12th, 2006 09:31 PM
how much trans and diff fluid militarygt General Tech 8 July 23rd, 2006 01:08 AM
Trans Fluid Dip Stick tllgdlkng General Tech 7 July 4th, 2006 04:15 PM
