Discussing went to the track in the 5.0 Mustangs Forum. Originally Posted by Darrell Did you replace the valve springs when you put the mild ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
#22 |
it is a k&n, but it was really dry, to the point where i made sure to wash it and re oil it today because i was scared of dirt getting through. i put on just enough oil to turn the filter a little red, i didn't drench it. should i still be worried and buy a new filter?
#23 |
I was just thinking you might be contaminating the MAF sensor with oil from the filter or too much dirt. But if that is not the case, try a new MAF.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
#24 | |
Asshole™
1990 Mustang LX
9.36@143 mph
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#25 |
would a 5.0 explorer MAF sensor work?
#26 |
Good question, I'm not sure. I know the 90 mm lightning MAFs require a chip burn to work, but they are pretty nice overall.
#27 |
does anyone know about the 2.4L mustang MAFs?
thats all the junkyard near me has and they have no 5.0L explorer motors left in the explorers. |
#28 |
91 mustang
266 ftlbs 191 hp (15.138 @92.91) @5000ft elevation
probrobly for emmisions
![]() Fender well cold air intake, 3:73's, eibach springs, 65mm TB, electric fans, 3g upgrade, smog delete, advanced timing, MSD cap and rotor, ford racing 9mm plug wires, 75mm Pro-M MAF, flowmaster sieres 40 delta flows |
#29 |
i know this thread is old, but i stumbled across it and thought i would share with you guys what the problem was.
pin 46 (i think) on the computer, the circuit was fried. soldered a jumper wire on and it fixed it. couple of months ago i made it back to the track and ran a best of 13.4 at 99.77 mph 1/8 mile was 8.4 the reason why my 1/4 is slow compared to my 1/8 mile is because the 4th gear synchronizer is toast, couldnt get it in granny shifting even, so i lowered the shift point to 4300 from 3rd to 4th and it went in and ran the 13.4 when i fix the transmission i should be able to see 13.1s/13.2s with no other changes |
#30 |
91 mustang
That's sounds a lot better, what is the elevasion were ur track is?
#31 |
#32 |
91 mustang
have u had it dynoed recently?
#33 |
god damn i hate my stupid 5300 ft above sea level. I need a fucking turbo to off set this shit.
#34 |
1993 5.ohhhh
14.47 at 96 mph
Thats alot better to hear instead of some 15s.
302 h/c/i
#35 |
91 LX
13.7@101
congrats those are good times
#36 |
#37 |
update...
ran a bunch of 12.9s the other night... bypassed the power steering tonight and ran a 12.8 at 103 mph 60' was 1.67, the track was cold... 1/8 was 8.15 i think it was 60 footing a little better than that the other night, but the track was too cold tonight... the 12.8 pass was the only pass where i didn't light my tires up on the launch... with suspension and moving the battery to the back i hope to 60' in the low 1.5 range (if possible) and run 12.7s it is a stock cam, the car had so many problems before that it didn't sound anywhere near stock... bad grounds causing a misfire is one... pin 46 is a ground for some sensors that was burnt up... i dont know why they did a MAF conversion on this car with a stock cam... and with my hot air intake and stock motor i dont think its doing too bad... Last edited by R0B0T : December 13th, 2008 at 01:38 AM. |
Threads Similar to: went to the track
| Going To The Track... | oh2swapped | 99-04 | 3 | April 10th, 2008 04:50 PM |
| Went to the Track | Humdesnuts | 99-04 | 7 | April 7th, 2008 08:35 AM |
| going to the track!!!!!! | 88stangGT | 5.0 Mustangs | 6 | March 26th, 2008 06:30 PM |
| Went To Track | jivepepper | 99-04 | 2 | November 17th, 2007 08:12 PM |
| track on LI | midnightrace | Modular Mustangs | 0 | March 12th, 2007 08:18 PM |
