TPS Problem?
Old November 5th, 2006, 07:10 PM   #1
88Horseman is on a distinguished road
TPS Problem?
A buddy of mine hooked up his Digital TPS Monitor to set my TPS voltage and his monitor didn't even power up when we turned on the ignition, its like the TPS isn't registering, but when we plugged it back to the engine with the car running, the engine idle changed. WTF?
We know his monitor works because we used it on his car. What could be the problem?
Old November 5th, 2006, 08:37 PM   #2
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
digital tps monitor? a simple voltmeter would work better than what that sounds like. I've never used a tps monitor but you sure as hell don't need one.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old November 5th, 2006, 09:41 PM   #3
Its actually pretty good. I've used one before. A voltmeter is too sensitive. Go here and check it out. The people are great. http://www.mass-air.com/Products.htm
Besides, I tried a voltmeter but I'm having a strange problem. I'm getting a constant 5volts to all of my sensors for some reason and it won't adjust. (yes, I elongated my screw holes on the TPS).
Old November 11th, 2006, 12:22 AM   #4
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
im getting consant 5 volts too wtf
85 svo. work in progress
Old November 12th, 2006, 06:56 PM   #5
Hey Terribleonexx88, I was talking to one of my buds and he told me he went to a mustang meeting of some sort and talked to a ford expert I think and the guy said that the 02 sensors will get too hot and burn on the inside. This will cause a constant 5 volts. If you haven't done so, try and replace your 02s and see what happens.
Old November 12th, 2006, 10:58 PM   #6
i looked at my o2 sensors 2day and i noticed one wire has broken off the o2 sensor so i think ill replace them
Old November 12th, 2006, 11:36 PM   #7
IcantDo55 is on a distinguished road
It always gets 5V in than varies the output due to the TP.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old November 13th, 2006, 12:32 AM   #8
so how do get it to read .98 v
Old November 13th, 2006, 08:13 PM   #9
So........ IcantDo55, do you mean the 02s being broken will cause the constant 5 v?
Old November 13th, 2006, 10:55 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Which wire are you guys probing???
Old November 13th, 2006, 11:46 PM   #11
the green one
Old November 14th, 2006, 12:46 AM   #12
Darrell...he's having the same problem I'm having. I still haven't fixed it yet. I just don't know what else to do. The Ford dealer doesn't even know.
Threads Similar to: TPS Problem?
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
Has your car ever had a problem? JASonic The Clubhouse 17 September 19th, 2007 06:19 PM
big problem need help 96gtponyred 96-98 12 August 22nd, 2007 02:36 AM
RIM Problem and Help trueballerisme 2005 - 2010 70 August 21st, 2007 09:55 PM
t-5 problem notsoslow50 5.0 Mustangs 7 August 17th, 2007 08:16 PM
