What do you guys think about sea foam?
LinkBack (1) Thread Tools
Old June 8th, 2008, 04:40 PM   1 links from elsewhere to this Post. Click to view. #1
1993 mustang GT
50fanatic is on a distinguished road
I was running with platinums and bad ignition wires for a while, getting horrible gas mileage like 11 to 12 miles per gallon in the city, until today when I installed motorcraft copper plugs and Taylor 8.2mm Thunder Volt wires. Runs a lot better now, but now I'm thinking about using sea foam to clean my valves for my 5.0. Is it a good idea?
Old June 8th, 2008, 04:51 PM   #2
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
Sea foam isn't bad. I sold lotsa that stuff when I worked @ the auto parts store. Many a "old timer" swore by it.
I myself like Barryman B-12, but thats just me. Basically, both do/can do the same thing. Sea foam leaves a slight oily film in its wake whereas the B-12 does not. Other than that, both will clean a crankcase, valves and injectors etc;.
And, the B-12 is cheaper.
I ran the B-12 in my '03 Eclipse. Used it every other fill-up and every 3rd oil change.
I was getting 37MPG HWY w/ synthetic oil (Valvoline).
EPA rated that car for 31MPG HWY
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old June 8th, 2008, 04:59 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
I have a bucket of dirty intake and exhaust valves, Ive tried to clean one with seafoam, and it will not clean off, I soaked it in seafoam overnite and it did nothing. I tried, STP inj. cleaner, pb blaster, wd 40, gasoline, motoroil, alcohol, and brake parts cleaner. brake parts cleaner worked the best, but did little.
Old June 8th, 2008, 05:08 PM   #4
1989 LX Vert - 1993 Notch
Fast
r.barn is on a distinguished road
I used it on my original engine for years.
When I tore down my 17 yr old engine with 100,000 miles on it
that had never seen the light of day and only 5-6,000mile oil changes (at best) .........
it had zero sludge or gunk in oil pan or under the valve covers
The top of pistons had very little carbon build up and very little
build up on the top of the valves.
Will it make your engine parts look like new? no
Will it keep your engine clean and sludge free? YES
The last President elected in anger of previous President was ....... Jimmy Carter
God Help Us
Old June 8th, 2008, 05:16 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
The best way to keep your lifter vally, underintake, and oil pan clean is to use a higher temp thermostat (190-195). PCV plays a huge roll in intake gunk.
Old June 8th, 2008, 05:16 PM   #6
ryans88gt's Avatar
^^^^ same with my motor that I never put any seafoam in....or anything for that matter other than 87 octane.
Personally, I would never put seafoam in my car. I would rather the deposits stay on the valves than foul a plug, wash the cylinders down, cause the seat to get fire slotted from junk holding the seat open when it breaks loose, ruin the O2 sensors and cats, etc... I say let sleeping dogs lay. It is a gimmic and not even one that works like rain-x
Old June 8th, 2008, 05:17 PM   #7
ryans88gt's Avatar
air/oil separator on the PCV line makes a world of difference.
Old June 9th, 2008, 03:46 PM   #8
1993 mustang GT
I'm using 180 thermostat and 87 octane, because I have stock 10 degree timing. I was using 93 octane until I heard that it's robbing power, due to the fact that my stock timing performs best with 87 octane. Where you pour the oil into and has a breather, look into it and it looks clean as s**t. Overall, my engine still looks new. It's a 93' and has 89,000 original miles. Not bad. Thanks for the info guys!
Old June 9th, 2008, 03:56 PM   #9
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
How do you clean your engine with it? Do you let the vacume tube suck it up?
Old June 9th, 2008, 05:20 PM   #10
ryans88gt's Avatar
Nah, pour a few bottles into your oil...
J/k
Old June 9th, 2008, 06:41 PM   #11
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
for seafoam your supposed to put 1/3 in your gas tank, 1/3 in your oil, and suck up the rest through a vuccum line...
Old June 9th, 2008, 06:44 PM   #12
1987 ford mustang gt
well see when shes done
And your not suppose to skip english class
Old June 9th, 2008, 07:28 PM   #13
1983 mustang lx
83fox is on a distinguished road
and when he says suck up the rest through a vacuum line, he means not for you to suck it up through a vacuum line, let the motor handle that haha
Old June 9th, 2008, 08:10 PM   #14
Smirnoff's Avatar
1982 GT t-top
yeah sorry i hated english definitely skipped that class a lot
Old June 9th, 2008, 10:08 PM   #15
nolife's Avatar
91GT, 88GT, 02GT
Keep in mind that the Ford valve covers (and others) have a baffle under the fill tube/breather hole, your looking at a metal shield in there, not the top of the heads
Old June 9th, 2008, 10:23 PM   #16
e3sean's Avatar
1988 lx
9.68@142
i hope your not saying rain x doesnt work. i live by that stuff
<font size=4><b>MILITARY CREW
Old June 9th, 2008, 10:33 PM   #17
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
dont want to hi jack the thread or anyting but what is a good way to clean out the engine like oil pan, gallies, and just get out any junk thats in there, the 88 i bought sat for 18 months so im sure its a little sludgy.
whats a way to clean it out and get it a little better?
Old June 10th, 2008, 06:05 AM   #18
JBIGBOOTSY's Avatar
1990 LX hatch
Drain your oil, buy some brake parts cleaner, bend the straw so that it is at a right angle, spray away, after it evaporates, put plug(s) in, and fill.
Old June 10th, 2008, 10:43 AM   #19
ryans88gt's Avatar
again, let sleeping dogs lie.
breaking up sludge in a high mile motor usually = bye bye motor.
That shit breaks loose and then plugs oil galleys and lifters and the next thing you know it is time for a rebuild.
Old June 10th, 2008, 02:04 PM   #20
78mach1's Avatar
ya that makes sense i guess.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/74870-what-do-you-guys-think-about-sea-foam.html
What do you guys think about sea foam? This thread Refback June 8th, 2008 10:44 PM
Threads Similar to: What do you guys think about sea foam?
Sea foam flattusmaximus78 94-95 3 May 15th, 2008 07:22 AM
Sea Foam Corey 5.0 Mustangs 5 April 17th, 2008 02:32 AM
sea foam for my 99 v6 with 49k miles Basics V6 Mustangs 18 November 3rd, 2007 12:59 AM
how to sea foam ?? 96gtponyred 96-98 5 July 22nd, 2007 12:53 PM
Help after using sea foam... 04GTAMPA 99-04 4 June 7th, 2007 10:16 PM
