Pulled engine last night...LINK TO PICS
Old November 23rd, 2005, 10:30 AM   #1
I8URVTEC is on a distinguished road
Last night I pulled the engine and transmission out of my '91 LX. It went pretty smoothly overall. I couldn't believe how rusted out the transmission crossbrace was! Anyway, here is some more info and pics...no use posting it twice:
http://franksperformance.com/Forums/...st=0&#entry751
Old November 23rd, 2005, 10:49 AM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
what's going to fill the void
Old November 23rd, 2005, 11:57 AM   #3
I plan on cleaning the engine bay while I save for the engine and trans combo I want. I want to put in a C4 transmission and a 331 stroker with either a supercharger or a turbo. That is the wish list anyway.
I am going to take the engine down to the block and have a look to see if it is good enough to make a stroker out of it. If not I will have to get another one. The block had 163k miles on it before I removed it.
Old November 23rd, 2005, 01:54 PM   #4
sAJ1420's Avatar
2000 Audi S4
sAJ1420 is on a distinguished road
Send a message via AIM to sAJ1420
sweet dude.. good luck
A U D I //S4 2000 6MT/TT/AWD
Stage 3 in the works.. 460+ awhp 455 lb/ft torque, 500+ awhp on race gas
Old November 23rd, 2005, 03:41 PM   #5
Thanks. Being realistic I know it will take me a few years to complete but when it is done it will all be worth it.
Old November 23rd, 2005, 04:56 PM   #6
sAJ1420's Avatar
2000 Audi S4
oh def. will be, what else you have in mind for it?
Old November 23rd, 2005, 04:58 PM   #7
what is your power goal?
Old November 23rd, 2005, 05:04 PM   #8
Ideally I would like around 450-500 hp at the rear wheels. I don't think that should be a problem with a 331 and boost from either a supercharger or turbo. The C4 can handle that power fine. As far as the rear end goes I am planning on just upgrading the 8.8.
Old November 23rd, 2005, 05:18 PM   #9
reason i ask is because have you ever thought of starting with an aftermarket block?
Old November 24th, 2005, 02:46 AM   #10
IcantDo55 is on a distinguished road
With those power goals I would NEVER think of using a stock block! Way too much time $ and sweet to hava a major failure that you could have prevented.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old November 28th, 2005, 01:26 PM   #11
87vert is on a distinguished road
Send a message via AIM to 87vert
especially when you can make the same power on a 200k mile stock motor.
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old November 30th, 2005, 12:04 PM   #12
I am not going to lie, I this is my first time doing anything like this...I am on a tight budget but I want to do this project correctly. What kind of suggestions would you all have for me? Should I shop around and find and buy the block and components I want and then have an engine builder put it all together? Should I just buy a crate engine and drop that in?
Old November 30th, 2005, 04:11 PM   #13
Crate engines are the easyest but they will not be built for your application. check out:
http://www.adperformance.com/
send Brian an email and discribe what you want and he will steer you in the right direction. I bought all my engine parts from him. Great service and knows his stuff.
-Mike
-Mike
Link to My Site
Stroked and Blown!
Old November 30th, 2005, 04:50 PM   #14
for 400hp throw in a stock motor, refreshed maybe bored over to a 306, and some forced induction and you'll be fine.
Old November 30th, 2005, 07:06 PM   #15
... when you build the 302W's for over 500hp they go with a aftermaket block like dart or world products, so even if you build for 400hp and plan on upping the juice later might want to get that aftermarket block.
Old November 30th, 2005, 08:31 PM   #16
but if you go for an aftermarket block go for 4digits.....
Old December 18th, 2005, 09:06 PM   #17
FastFiveO's Avatar
FastFiveO is on a distinguished road
Send a message via AIM to FastFiveO Send a message via MSN to FastFiveO Send a message via Yahoo to FastFiveO
good luck with it.. aleast you had a cherry picker to get your motor out..lol
86 Mustang GT- twinturbo nitrous injected and much more.
86 Bronco- few mods
Old January 17th, 2006, 08:41 PM   #18
gearheadfred5.0 is on a distinguished road
500-600 (at the crank) is doable with a stock block. There are many people that have hundreds of passes at that level without problems. The biggest factor is running lean and revving too high (6000+). I would go with a stand alone computer instead of "chipping" the stock computer. Western Digital has a cool one for about $1000 that plugs into the factory harness and is speed density, so you can save money on mass air sensors and all of recalibrating for injectors etc. There are others too but you will need a laptop. You will need a good transmission with billet/SFI flywheel and scattershield (unless you don't like your legs). Rear end will need to be upgraded too. A cage and sub frame connectors (if you don't already have them) and reinforce/weld boxes. There is a lot in the body of a Fox when trying to get power to the ground and not the twisting of the body.
Cheap
Alternative
Mustang
Always
Runs
Odd
Old January 18th, 2006, 01:26 AM   #19
if one was to spend all that money what is a little extra for the aftermarket block?
Old January 18th, 2006, 09:15 PM   #20
vfast will become famous soon enough
didn't you post those on MF awhile back?
Threads Similar to: Pulled engine last night...LINK TO PICS
couple new various night pics!!!!check em out droppedbass87 96-98 4 August 13th, 2007 12:22 AM
Friday night Street Night - Richmond Drag L33T Southeast 9 June 19th, 2007 11:32 PM
Anyone got engine pics of 03 Gt spetsnaz103 99-04 5 December 12th, 2006 02:58 AM
Took Some Pics Last Night And Today! Rantheman Pictures 13 November 7th, 2006 08:35 PM
new pics of my new engine! Drgnracin72 Multimedia 10 May 11th, 2006 07:29 AM
