Heating Vents Cont
Old November 6th, 2006, 11:14 AM   #1
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Heating Vents Cont
After replacing the heater core I only have air coming out of my defrost and floor vents. I thought It was a vacume line so this weekend pulled the dash again to double check and every thing was hooked up. when I was replacing the heater core, there was one black and white vacume line I pulled that was on the passnger side that was hooked to a silver looking canister about 2 in tall just to see what it was and noticed that it was a sucking in air. so I let it hang while I was working on the heater core and it quit sucking air after a while and now there is no vacume at all. I just wonder if I have to hook up some kindof external vacume (like a shop vac with air hose used in fish tanks) to re initiate a vacume in the system or what. I had a post on here earlier but cant find it and it suggested a yellow vacume hose on the drivers side but still towred the middle of the dash. I didnt see a compleatly yellow hose but I did see a black/yellow striped hose and they were all in connecetd. any ideas?
Old November 6th, 2006, 08:32 PM   #2
OTreborO is on a distinguished road
what can I say
89 90 has a yellow hose that goes to the vent that controls the defrost
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old November 6th, 2006, 09:31 PM   #3
craigstoys is on a distinguished road
My 89 goes yellow-panel/defrost motor
white-outside air motor
both red and blue go to the floor/panel motor
black is incoming vacuum source the hose going through the firewall between the heater hoses
Old November 6th, 2006, 09:37 PM   #4
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
isnt it controlled by a thin cable attached to a flapper
85 svo. work in progress
Old November 7th, 2006, 03:21 PM   #5
Holy Dick Castle!
dr.gonzo!'s Avatar
hey OTreborO. you did say it should be high in the dash in the center but still towred the drivers side right? just to make sure before I pull the dash off for the 3rd time. I really dont pull the hole thing off I drop the steering colum and undo the torq bolts on the uper part just to give me about a foot of room ie.. defrost vents and behind the speaker grill and remove the 2 8mm bolts behind the kick panels. I have seen some bad picks of the plastic part off but they left the metal fram on. looks like a lot of trouble. this is not me. I dont even come close to this disaster.
[/img] im guessing your talking about the yellow vacume line by the radio in the first pic
Threads Similar to: Heating Vents Cont
over heating jersey98gt 96-98 40 September 20th, 2007 01:54 PM
over heating? kreil45 5.0 Mustangs 8 May 24th, 2007 03:47 PM
How to remove side vents with honey comb inserts? BTA99GT Visual 4 March 2nd, 2007 07:43 AM
Heating Vents dr.gonzo! 5.0 Mustangs 2 October 31st, 2006 02:01 PM
