Discussing Turbo Charge in the 5.0 Mustangs Forum. I am looking at making a junkyard/turbo kit and I am still a little ...
Old November 6th, 2006, 02:45 PM   #1
dr.gonzo's Avatar
Turbo Charge
I am looking at making a junkyard/turbo kit and I am still a little confused as far as the exhaust . is it a compleaty closed system or does the exhaust evntly make its way out of the car other than the wastegate and blowoff valve I have seen a few pick of it installed on a engine out of the car
FREE LUNCH, FINAL
WISDOM, TOTAL COVERAGE... WHY NOT?
Old November 6th, 2006, 04:21 PM   #2
IT'S TURBO TIME
TurboLX's Avatar
1990 Mustang LX Turbo
basically this is how it works the exhaust powers the turbo which causes the turbine wheel to spin and sending forced air through the pipes through the intercooler which cools the air from the turbo to the intake and forces it into the engine.a wastegate is kinda like a bov but it stops boost from creeping up because you dont want to be doing 50 and then start accelerating to 100 with out moving your foot and a bov is used to let out excessive air that is not needed because you dont want to much air going in the motor because that will lead you to a rebuild on the motor and give you wierd engine sounds like a rod knock
Put up, Shut up, Line Up And Get Beat Up!!!
Old November 6th, 2006, 04:22 PM   #3
IT'S TURBO TIME
TurboLX's Avatar
and the exhaust exits behind the turbo out the down pipe
Threads Similar to: Turbo Charge
Turbo or Super Charge? Micro Ford 2005+ 72 December 19th, 2007 04:25 AM
Turbo charge V6 Alex McCartin V6 Mustangs 2 November 11th, 2007 03:27 PM
Super charge or not? mustangprincess00 V6 Mustangs 44 September 1st, 2007 02:13 AM
Super charge or not? mustangprincess00 V6 Mustangs 2 August 31st, 2007 06:41 PM
Help!!!Serious Charge problems Rice Eater 5.0 Mustangs 5 August 9th, 2006 02:40 AM
