02 STEEDA Q
95 5.0 Wont Start At all. (help!)
Hello Guys and Gals,
Questions. My Wife's 95 5.0 Will not satart. when we put the key in everything else works fine, but it will not crank. no click or anything. the battery is good, thought might be the starter, but we put a new one in and thats not the case (unless its a bad starter from the shop) i thought maybe it would be the clutch switch since its a 5spd. anything else might be a cause? thanks! Tony |
48.47@ 12.58
bad starter sounds like it to me. or a bad fuse could be it al well. when starters go the starter fuce usually does as well.
try replacing the starter relay on the driverside fender before changing the starter
85 svo. work in progress
RIP Justincredible! God Speed
Check ALL the fuses including the ones under the hood.
Could be the Relay Control Module fuse....if its blown, it will not let the car start.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
95 opalfrost gt
Heres something that might help ya out. Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark. Most of the items are electrical in nature, so a test light, or even better, a voltmeter, is helpful to be sure they have power to them. No spark, possible failed items in order of their probability: A.) MSD or Crane ignition box if so equipped B.) Coil C.) TFI module D.) PIP sensor in distributor E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. H.) Computer See the following links for wiring diagrams... http://www.autozone.com/servlet/UiBr...3d8016713c.jsp for 79-88 model cars http://www.autozone.com/servlet/UiBr...3d8019595a.jsp for 89-93 model cars http://www.autozone.com/servlet/UiBr...3d801ddb3c.jsp for 94-98 model cars 2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: A.) Moisture inside distributor – remove cap, dry off & spray with WD40 B.) Distributor cap C.) Rotor D.) Spark Plug wires E.) Coil weak or intermittent - you should see 3/8" fat blue spark with a good coil 3.) Spark at spark plug, but no start. Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct. Two reasons: 1.) If it backfires, the chance for a serious fire is increased. 2.) On Mass Air cars, the computer needs to measure the MAF flow once the engine starts. If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t, then it is a computer or timing issue: see Step 4. Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground. [img] http://forums.stangnet.com/attachmen...7&d=1134531771 [/img] If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. No fuel pressure, possible failed items in order of their probability: A.) Tripped inertia switch – Coupe & hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter. Look for 12 volts at the Pink/Black wire on the fuel pump relay. C.) Clogged fuel filter D.) Failed fuel pump E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid. F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running. Fuel pressure OK, the injectors are not firing. A.) A Noid light available from Autozone, is one way to test the injector wiring. B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too. a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on. b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold). c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors. Note that the injector red wires are powered up whenever the ignition switch is in the Run or Start postion. The computer provides a ground to turn the injectors on. Make sure the computer's power ground is connected. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. The wire goes into the harness at the starter solenoid. 4.) Spark & fuel pressure OK. A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car. B.) Failed computer (not very likely) C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently). D.) Firing order off: HO & 351 use a different firing order from the non HO engines. HO & 351W 1-3-7-2-6-5-4-8 Non HO 1-5-4-2-6-3-7-8 E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
i didnt see it on here, but you have a neutral override switch. if you have a 5spd.. 1 make sure youve got the clutch in.. 2.. id check the switch if arcing the starter solenoid doesnt do anything for ya.
I would check the clutch interlock switch cause when mine messed up I didn't have any click or nothing. When I ran a jumper wire it fired right up.
Yeah I would try crissing the studs on the relay and see if it will turn over if nothing happens then start with checking fuses and go from there, I had the same problem with my 89 not starting and i changed the relay and I havent had a probem since.
Lee |
Threads Similar to: 95 5.0 Wont Start At all. (help!)
| Wont Start | caintcatchmyGT | 96-98 | 3 | September 10th, 2007 11:02 PM |
| wont start | snailstang | 96-98 | 24 | August 30th, 2007 09:46 AM |
| need help...car wont start | orlyr21 | V6 Mustangs | 8 | January 13th, 2007 08:17 PM |
| wont start?? | shadowgames81 | 5.0 Mustangs | 10 | January 7th, 2007 09:10 PM |
| 91-92 5.0 gt wont start | sturcotte3 | 5.0 Mustangs | 0 | January 1st, 2007 05:40 PM |
