Discussing what would you do? in the 5.0 Mustangs Forum. Ok if you guys were going to build a fuel injected big in windsor [408] ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1987 ford mustang gt
well see when shes done
what would you do?
Ok if you guys were going to build a fuel injected big in windsor [408] what would you do to it.
I would like to build one and would like to hit the 450-500rwhp mark on motor |
1988 lx 5.7
11.6@109
edelbrock efi spyder intake and a set of brodix heads
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331 MILITARY CREW USAF LUKE AFB AZ, E-5 SELECT 7995 AMMO I.Y.A.A.Y.A.S |
I was thinking a set of dart 225cc heads, trick flow box r upper and a custom grind hydraulic roller, just something i want to try and i want to see what it would do untuned do you think 500rwhp untuned is out of hand.
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
will it be all motor?
GTConcept05: i'm dying of cancer here,, please jack me off for me ^^ ![]() slow car club - crew member 1 of 9 join www.moddedautos.com i had my bowl of WIN for breakfast. did you? |
it will see nitrous duty as well but i would like to hit 450-500 rwhp on motor
Nowhere to be found
225cc AFR's
Well, guys its been real and its been fun, but it hasn't been real fun for me the past 3 months. Money has been tight and need to cancel my cable service to save what I can. I hope to chat with ya'll in 6-7 months from now. Bye!
Asshole™
1990 Mustang LX
9.36@143 mph
I'd build it just like the one I'm building now which will make 675-700 horsepower naturally aspirated and run on pump gas. I'll have dyno numbers after its finished. As always it has a set of Trick Flow CNC 225 R-series heads. After what I've done with that head in the past I feel it is the best 225cc head on the market. I'd also use a solid roller. You are going to need an aftermarket EFI system. For one you will need to get rid of the factory 6250 fuel cut off as this engine is going to peak in the 6500 rpm range and you will need to cut the percentage down of fuel at start up with big injectors or it will flood the engine when you start it.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
